key fob help
Old Feb 11, 2011 | 03:14 PM
slobalt08's Avatar
key fob help
I replaced stock batt with optima yellow since stock was completely dead, now key fob wont lock or unlock doors or anything with the key fob. It can't be the key fob battery cause the DIC tells you if that's low. Please help! Locking and unlocking the doors manually is a huge inconvenience!
Old Feb 11, 2011 | 03:18 PM
smthomas556's Avatar
You need a Tech II and the BCM will need to be programmed to your remotes. Stealership time
Old Feb 11, 2011 | 03:41 PM
slobalt08's Avatar
#@%#$&Y@! Hate the stealership...
Old Feb 12, 2011 | 03:12 AM
EmperorJJ1's Avatar
theres a how to program your remote urself somehwere. idk where thou
Old Feb 12, 2011 | 03:37 AM
heathkidder's Avatar
i had this problem and it was just the fuse
Old Feb 12, 2011 | 03:09 PM
c4w18's Avatar
check your fuse....also, search the forums. there's a major problem with the solder on cobalt remotes. one of the legs that holds the battery in place and provides power often comes loose because the solder joint is weak. pop open your key fob and check your board for broken legs near the battery. changing your battery shouldn't have affected the remotes at all because i've performed the same stock to yellow top procedure in the past and nothing affected the remotes.
Old Feb 12, 2011 | 03:49 PM
slobalt08's Avatar
yeah but my battery was stone cold dead for a good week so maybe it hard reset the ecm also which fuse?
Old Feb 12, 2011 | 03:56 PM
tylerjclance's Avatar
USA Y U NO HAVE AUTOBAHN?
i had to re-sauder(sp?) the connectors inside of mine and it worked like a charm
Old Feb 12, 2011 | 04:20 PM
slobalt08's Avatar
im telling you its not that both remotes dont work the remote worked before my battery died and i haven't touched my keys since then till i replaced the battery yesterday
Old Feb 12, 2011 | 11:01 PM
5hizn1t's Avatar
Sometimes the FOB's become out of sync if the battery is dead for a while on the car or on the FOB. If it is just a sync issue, all you have to do is hold your lock and unlock buttons on the FOB at the same time while your near your car and after 20 seconds or so your locks on the car should cycle locked/unlocked. I have to do it all the time for people that only use one of their FOB's and leave the other in the closet or dresser and then try and use it.
Old Feb 13, 2011 | 12:49 PM
slobalt08's Avatar
I tried that out of curiosity it didn't work. I'll give it another try tho to humor my self. They say I could bring it to a locksmith if I don't wanna go to the dealer. So might give that a shot.
satisfied
Oct 19, 2015 12:35 AM
Extreme Dimensions
Sep 24, 2015 07:51 PM
Shane H
Sep 20, 2015 11:56 AM
Gugi96
Sep 15, 2015 12:24 AM
jthwjde
Sep 7, 2015 09:24 AM
