LED question!
LED question!
I found some HID werks LEDs and they are 3157, I tried them in my tail lights and they worked but wouldn't light up when I pressed the brake, so I'm wondering if anyone knows of 3157 LEDs that will work in the tail lights, and if someone could help me with the rapid blinker problem too that would be great!
There are two kinds of leds, single and dual filament. You need a dual for running plus brake lights (and blinkers)
First thing to try is plug the bulb into the socket upside down.
If that doesn't work you probably have the wrong bulb.
As for hyper blinking, you'll need to install resistors on either side. search Ebay for 50W 6ohm resistors they should be around 8 bucks for a set of 2. hook them up between the positive and negative of your bright (brake.blink) light harness and mount them away from anything flamable/meltable since they will get pretty hot.
ya i dont think switchbacks will work for the brake but you can try turning them around and see if that changes anything. brake lights are indeed 3157
Lamp Replacement Guide View All Bulbs
ya i dont think switchbacks will work for the brake but you can try turning them around and see if that changes anything. brake lights are indeed 3157 Lamp Replacement Guide View All Bulbs
Iceberg
Sep 29, 2015 12:33 PM
