LED Wiring...
Old Mar 26, 2009 | 09:09 AM
MikeSS1605's Avatar
LED Wiring...
So It has been 6 years since I took an electronics class in HS. I just ordered some LEDs from ebay that come with the resistors for 12V applications. When I wire these, Do I need I resistor for each LED? Im going to put 8 in the cup holder and 2 in each door handle. Im assuming I should just be able to run it in parallel and put 1 resistor at the begining on the positive side and be fine. am I correct in this assumption? Thanks.
Old Mar 26, 2009 | 10:48 AM
NCC-2000's Avatar
I don't know if it's correct or not, but that's how I would wire them up.
Old Mar 27, 2009 | 12:51 AM
EmperorJJ1's Avatar
yes you must puit a resistor on each led and you can wire them up in series. the longer prong and smaller of the 2 pieces (in the diode itself) will be your pos
chefhhr
Oct 26, 2015 10:36 PM
How to Guide
57
Oct 15, 2015 11:56 AM
dieGone
Sep 23, 2015 10:20 AM
jonnycat
Sep 19, 2015 12:58 PM
ATOMbomb
Sep 11, 2015 10:48 AM
