Lighter plug always on power?
Old Jul 9, 2006 | 03:11 PM
MrTRiX's Avatar
I have sirius radio powered by the lighter plug in the front of my car, how can I wire this plug to turn off when I turn the car off?
Old Jul 9, 2006 | 03:39 PM
Raven's Avatar
wire it to a switched 12v source
Old Jul 9, 2006 | 05:54 PM
MrTRiX's Avatar
Wire the sirius plug or the lighter? How?
Old Jul 9, 2006 | 06:08 PM
Xenozx's Avatar
you can buy a product from a local hardware/auto parts store called "Add a plug". It will add a connection to your radio fuse. You cut the end off the lighter adaptor for your sirius and hook it into the add a fuse and run the wire behind your dash or out of sight. At that point it will power on when your radio powers on, and shut off when your radio shuts off. Pretty easy to do dependant on how badly you want to hide the wires.
Old Jul 9, 2006 | 07:06 PM
MrTRiX's Avatar
Thanks. I tihnk im just gonna go back to futureshop and pay the extra $15 bucks to get it hardwired, as it is I had to pay 12 bucks on a lighter plug adapter cause the sirius one kept poping out so its not worth my money to try anymore. But thanks for the assistance.
Old Jul 9, 2006 | 07:11 PM
JimmiLS05's Avatar
Unplug it when you get out and just plug it back in when you start driving
Old Jul 9, 2006 | 07:13 PM
Xenozx's Avatar
laziness Half the time I dont remember to do that with my radar detector
Old Jul 9, 2006 | 07:43 PM
iLLmaTic3s's Avatar
hardwire it..cut the end of ur cigg plug. wire the black wire w/ white on it to the sunroof fuse...if u dont u can do the radio fuse...then ground it to the fuse box. there is a screw on the bottom of the fuse box that is ground...the fuse box is located by the passangers seat to the right of the shifter.
Old Jul 10, 2006 | 08:57 AM
SRT-S2K's Avatar
Whoa dont cut that plug!!! you can't cut the plug on that unit!
Old Jul 10, 2006 | 09:42 PM
iLLmaTic3s's Avatar
yes u can...y cudnt you...most if not all those units run on 12v. if u wanted to re use the plug down the raod just simply tie it back into it.
Old Jul 12, 2006 | 02:36 PM
SRT-S2K's Avatar
some of those sirius and XM radios that plug into a cig lighter only run off 6v, just giving a warning. Look at the plug and make sure it donent convert into 6v.
Old Jul 13, 2006 | 12:36 AM
iLLmaTic3s's Avatar
all sirius run on 12v...Xm runs on 5V, thats when u need a additional cigg plug to hardwire in. they..the new sirius units to come out w/ run on like 6v or something...so for now..do it my way..until u cant..haha
Old Jul 13, 2006 | 09:20 AM
Bandit2941's Avatar
You can't run it to the radio fuse -- unless you want it to be hot all the time like it is now!! Use the sunroof or power window fuse.
Old Jul 13, 2006 | 09:36 AM
iLLmaTic3s's Avatar
well yes...u want to try to find something else that turns off w/ the car...sunroof and some others..
Old Jul 13, 2006 | 12:46 PM
SRT-S2K's Avatar
they do have XM and sirius that run on 5v and 6v. It depends on what kind you buy I think the comander for Sirius runs off 6v. just makin sure cause you can blow out your whole unit.
DarrenGC
Dec 24, 2021 01:55 PM
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
agentirons
Oct 16, 2015 02:11 AM
717ssbalt
Oct 2, 2015 04:01 PM
Stuff
Oct 1, 2015 05:47 PM
