Low beams with high beams? (Projectors)
Old Nov 12, 2012 | 12:55 PM
fullmetal289's Avatar
Question Low beams with high beams? (Projectors)
I am trying to figure out how to use a relay to wire up my low beams to stay on with my high beams in my projector set. I am trying to figure out this thread..
yourcobalt. com/forums/install-guides-diy/23962-how-make-your-low-beams-stay-your-high-beams.html
But they aren't very clear on where to get the 12v source and what relay to specifically buy that has the same pin layout as mentioned in the topic and they also failed to mention what gauge wiring should be used to carry the current for the high and low beams. i would post there but the thread was closed. Any help would rock.
btw, i dont use any ballasts or whatever, just a straight plug and play setup.. my halos and leds are wired into my parking lights but that shouldnt affect the lows and highs at all.
Old Nov 13, 2012 | 03:26 AM
EmperorJJ1's Avatar
https://www.cobaltss.net/forums/how-...jectors-68252/
Old Nov 14, 2012 | 03:17 PM
WARNING:
This IS NOT recommended if you are NOT using the relay harness to power your ballast.
I don't use a ballast to power my headlamps, what does this mean?
Also, I don't want to use the 12v power source as a direct battery terminal.. Is there another source that wouldn't require an inline fuse?
Old Nov 14, 2012 | 10:09 PM
EmperorJJ1's Avatar
yes but why would you not want to use a fuse
Old Nov 14, 2012 | 10:10 PM
CannonBalt's Avatar
^ This
Old Dec 26, 2012 | 02:24 PM
okay i didnt mean that.. what i meant was i didnt want to run wire all the way to the back of my car where the battery is, anyone know of a 12v source in the front of the car?
Old Dec 27, 2012 | 01:45 AM
EmperorJJ1's Avatar
ya the jumper post on the fuse box. theres a thick wire going from that to the battery so you can add whatever you need for the most part there
no_ss
Oct 18, 2015 11:58 PM
HEATON
Oct 16, 2015 07:21 PM
DANRICKARD
Oct 1, 2015 12:08 AM
importkiller
Sep 30, 2015 07:18 PM
Slick_Nick
Sep 28, 2015 09:15 PM
