LOW volume output of new head unit
Old Aug 7, 2009 | 07:19 PM
SchmidtUSAF's Avatar
freshly installed pioneer 4100 deck works like a champ except the volume has to be cranked to 62 (max volume) to hear anything at all. Whats the problem here?
Old Aug 8, 2009 | 12:55 AM
EmperorJJ1's Avatar
more info needed. what harness did u use? how is it wired? pioneer or non pioneer?
Old Aug 8, 2009 | 12:59 AM
2007 LS model, non pioneer system in the car but its a pioneer deck....used the PAC C2R-GM11 at first then cut the connectors and just did direct connect since it needed to be re-pinned anyways.
Old Aug 8, 2009 | 01:22 AM
EmperorJJ1's Avatar
cut the rca's? from the pac harness
Old Aug 8, 2009 | 10:09 AM
not the RCA's the actually harness connector the clip thing...it had to be repinned anyways so i just cut them and did it that way.
Old Aug 8, 2009 | 10:11 AM
EmperorJJ1's Avatar
hmm.. maybe bad connection there?
Old Aug 9, 2009 | 01:42 AM
i dunno, my buddy is an electrician and did the wiring. I certainly trust him the most when it comes to that stuff. Could it be something to do with a fuse perhaps? My gauge cluster lights are out as well as my rear running lights. I know that should be just a fuse but we will see if that fixes something.
I appreciate the help...
another thing, I had the speaker wires spliced directly from the wiring harness to the harness that comes with the deck and got no audio and now that I hooked up the RCA's instead and I get sound but really faint sound. Any idea what thats all about?
Old Aug 9, 2009 | 03:10 AM
Nighthawk243's Avatar
RCA's... are you using an amplifier?
Old Aug 9, 2009 | 03:11 AM
EmperorJJ1's Avatar
electrician doesnt necessarily mean good with cars... sounds like the gm lan is being tapped for something. also sounds liek the pac harness was fucked to begin with and no way u can return it now
buy a metra gm-lan-03 and follow the instructions
Old Aug 9, 2009 | 12:51 PM
the GM lan harness came with RCA's and not just a normal speaker wire setup. Granted I tried cutting those off and wiring them to the head unit speaker wire connections with no luck. That gave me no audio. I also dont have the clips that hook the harnesses together. So if i got a metra harness I would be altering that to hook **** up. I have all the wires spliced exactly how they should be and from where they should be. The speaker cables are the ones that dont make sense since I bought a PAC C2R-GM11 and I cant find any information on those ones coming with RCA's on it.
ahhh they gave me a GMCOL11 thats why...still says compatible with 2007 cobalt
http://www.autosoundcentral.com/Peri..._p/gmcol11.htm
you have to realize that my setup is weird right now.....the clips coming from the cobalt are cut and gone so that I could splice the wires from the car to the wire harness (gm lan). In doing that the chime retention thinger is gone and im fine with that and also I have the RCA speaker wires hooked to the head unit.
I have the worst luck...
my rear running lights dont work as well as my gauge lights. I check all fuses under the hood and in the fuse panel in the passenger seat area and nothing is blown at all. What could be the problem? This problem stays regardless of the head unit hooked up or not.
stock 4 speaker setup, no amp
Last edited by SchmidtUSAF; Aug 9, 2009 at 12:51 PM. Reason: Automerged Doublepost
Old Aug 9, 2009 | 01:23 PM
EmperorJJ1's Avatar
sounds like ***** all messed up. and im thinkin the gm lan wire is being tapped messing up the lights
what id recommend is starting from scratch and scrapping the stupid module. just direct wiring the speaker wires, ground and constant power. then running an acc from the fuse box
Old Aug 9, 2009 | 03:54 PM
thats exactly what I have going on...I scrapped the GM LAN harness a couple days ago. I am still having issues even after that. Gimme a minute and I will take some pics for you.
a guy from Justanswer.com
The PAC C2R-GMCOL11 is for Factory Amp..........
If you have the Factory Amp, be sure the Blue or Blue / White has 12 Volts when radio is ON.
Otherwise, the vehicle may not have an AMP, which would explain the "low" sound.
Some of the adapters require you to cut off the RCA connectors & Hardwire to the cut wires
the blue from the headunit is to be the remote turn-on for an aftermarket amp correct? Where else could i connect that?
Last edited by SchmidtUSAF; Aug 9, 2009 at 03:54 PM. Reason: Automerged Doublepost
Old Aug 9, 2009 | 08:16 PM
EmperorJJ1's Avatar
ya scrap the rcas... that explains the low volume. those should be hooked up to the speaker outputs. Make me a list of exactly what wire color in the cobalt harness is hooked up and to what most importantly what the red acc wire is hooked up to
dont connect the blue/white remote turn on wire to anything
Old Aug 9, 2009 | 08:39 PM
purplehaze03's Avatar
the gm lan adapter should have a volume control on it if its the one to retain onstar? is that the one you have?
Old Aug 9, 2009 | 11:55 PM
thats goofy though cuz I had scrapped the RCA's before and had no audio, I might have missed something though. I will report back with my findings...if that doesnt work then I'm bringing it in to a professional
Old Aug 10, 2009 | 02:50 AM
EmperorJJ1's Avatar
if thats the case double check your pioneer has output on the speaker wires. check for AC voltage on all 4 channels
Old Aug 10, 2009 | 11:43 AM
ALL IS WELL!!!!!!!!
ok so scrapping the RCA connectors and going with the other speaker wires worked like a champ. I have no idea why it didnt work to begin with but I dont care anymore its working perfectly and sounds great.
EmperorJ thanks for all the help
HEATON
Oct 16, 2015 07:21 PM
agentirons
Oct 16, 2015 02:11 AM
Slick_Nick
Sep 28, 2015 09:15 PM
Sep 28, 2015 12:51 PM
