Mini Morimoto D2S Retro
Old Aug 24, 2010 | 11:29 PM
arman14's Avatar
Originally Posted by SchmidtUSAF
I cant get my back reflector piece off of those stupid pegs...what did you do for that?
Just put it back in the oven and pull it out.
they look great!
Originally Posted by ChevyRockstar
Looking good
Thanks guys
Old Aug 25, 2010 | 08:06 AM
SchmidtUSAF's Avatar
Started my retrofit last night after work and all I have left is aiming and resealing. That will have to wait till after Labor Day though...vacation time. The Morimoto H1 5000K bulbs are out of stock at TRS right now anyways so that kinda works out.
Old Aug 25, 2010 | 03:50 PM
wantedSS/TC's Avatar
looks good. I plan on doing the same retros on my car!
Old Aug 25, 2010 | 04:34 PM
I'm just curious how you got them to fit without have wing nuts and bolts?
was a little "cloudy" in that area.
how much did you take off of the back of the reflector bowl?
thanks!
Old Aug 25, 2010 | 10:02 PM
arman14's Avatar
Looks like you're almost done
Aiming is really easy with this projectors, shouldn't take long.
Did you have to modify the reflector with the h1 projectors?
Old Aug 25, 2010 | 10:15 PM
arman14's Avatar
thanks!
Thank you sir
These projectors don't need wing nuts and bolts, you just clamp it in the reflector and secure it with the projector locking nut.
I had to completely sand down the reflector bowl for the projector to fit, it wasn't a big deal.
Old Aug 26, 2010 | 01:45 PM
deuce's Avatar
retros
On your morimoto minis, what did you order for your retro install? Was it plug and play?
Im looking online and wanting to do my first retrofit, but unsure what i need or how to do it...
Old Aug 26, 2010 | 01:54 PM
I see what you mean by locking nut. Seems pretty easy actually.
Remove halogen housing for halogn bulb, trim area around old bulb insert and screw in projector.
The wiring harness comes with it if you order it in a package. Makes it plug and play essentially.
Old Aug 26, 2010 | 02:12 PM
samsumthing's Avatar
all you need for retros is headlights, projectors, shrouds, bulbs and ballasts, and a relay harness. oh you also need some patience. lol
Old Aug 26, 2010 | 05:04 PM
kevinj4891's Avatar
if you don't mind, how much did you spend on the entire set up?
i would really like to get someone to do this for me, either to my stock ones or my gen4's. i just don't know anyone local (California)
they look great
Old Aug 26, 2010 | 05:15 PM
  #36
CudaJoe's Avatar
wow those look awesome! If the BUYHIDs.com projectors that I bought fail me down the road, I think I will go this route.
Old Aug 26, 2010 | 07:17 PM
  #37
deuce's Avatar
the quality of this projector to the buyhids projector is night and day if you do some research (meaning the morimoto is higher quality)
Old Aug 26, 2010 | 09:01 PM
  #38
arman14's Avatar
Everything was plug and play
This is the kit I got http://www.theretrofitsource.com/pro...d08187fe038702
Old Aug 26, 2010 | 09:02 PM
  #39
arman14's Avatar
Working with these projectors is easier than working with the FX-Rs
Old Aug 26, 2010 | 09:05 PM
  #40
arman14's Avatar
they look great
I spent under $350 including headlights.
You may want to check www.hidplanet.com, there's lot of retrofitters from California there.
Old Aug 26, 2010 | 09:06 PM
  #41
arman14's Avatar
Thanks CudaJoe and yea this projectors really worth the buck.
Old Aug 26, 2010 | 09:56 PM
  #42
deuce's Avatar
yea matt from trs emailed me back and said that is the best one for the cobalts, since its pretty easy to install...
I dont really have the funds right now but will get this kit eventually
Old Aug 27, 2010 | 12:43 AM
  #43
arman14's Avatar
Get it, you won't be disappointed
Old Aug 28, 2010 | 05:13 PM
  #44
arman14's Avatar
I finally had a chance to take some pics of the retros mounted on the car,
Output shots coming soon.
I highly recommend this projectors to anyone looking for an affordable yet efficient retro, and what better place to get them than The Retrofit Source online: headlight upgrades for all applications, excellent customer service,custommer support, top notch quality products, couldn't ask for more.
Now onto the pics.
Old Aug 28, 2010 | 05:15 PM
  #45
rico's Avatar
awesome work
Old Aug 28, 2010 | 05:18 PM
  #46
arman14's Avatar
Thanks rico
Old Aug 28, 2010 | 05:20 PM
  #47
rico's Avatar
np might get u to make me a set hehe
Old Aug 28, 2010 | 05:24 PM
  #48
arman14's Avatar
I'm going to build a set with FXRS projectors
Let me know if you're interested
Old Aug 28, 2010 | 05:25 PM
  #49
rico's Avatar
ill have my stockers and lenses avalaible
Old Aug 28, 2010 | 05:27 PM
  #50
arman14's Avatar
Nice
It'd be cheper then.
