more p4000dvd problems..
Old Jul 25, 2010 | 04:36 PM
brickloaf's Avatar
well I was trying to set the custom EQ on the HU just a second ago, and the manual says that if i make any changes, it should be saved for the next time i start the car...but as soon as i turn the car off and turn it back on, all the changes i made are gone and its back to normal. Anyone have any ideas? there isnt like a save button or anything and theres no way im about to set my EQ everytime i get in my car.
any help appericated
Old Jul 25, 2010 | 04:40 PM
reaper89's Avatar
is everything else saving?
Old Jul 25, 2010 | 04:45 PM
iboost's Avatar
^This...
Old Jul 25, 2010 | 04:49 PM
brickloaf's Avatar
Originally Posted by Chinelli3589
^This...
all the other EQs are presets so you cant change them anyways
as far as i know the custom EQ should be the only that you can change
Old Jul 25, 2010 | 04:52 PM
iboost's Avatar
what about if you program like radio stations or something. Do they reset after you turn off your car?
Old Jul 25, 2010 | 07:10 PM
brickloaf's Avatar
hmmm ill check in a second and let you know, ive literally never listened to the radio with this HU
Old Jul 25, 2010 | 07:12 PM
iboost's Avatar
yea I don't listen to the radio on mine either...****, I took the antenna off my car...
Old Jul 26, 2010 | 12:16 AM
EmperorJJ1's Avatar
subd to help
Old Jul 26, 2010 | 04:03 AM
reaper89's Avatar
another bump to find out. I dont mess with the EQ on my 4200dvd, i use the preset. but if your stations/settings arent saving then i say its a problem with the H/U itself, or the constant being supplied.
Old Jul 26, 2010 | 03:54 PM
brickloaf's Avatar
ahh just checked it and nope! the radio presets do not save either...
im trying to remember what wire my constant is tapped into but i cant remember...although im fairly decent at wiring so im confident that its in a good spot
Old Jul 26, 2010 | 04:22 PM
mccullj's Avatar
thats what i was gonna say... your "constant" wire u speak of, i would refer to as a memory wire. im pretty sure the memory wires are usually yellow and should have a constant 12v source running to them at all times. even with the car shut off. this would keep the power going to the memory therefore allowing ur HU to save the settings. don't quote me on the yellow wire part of this though. let someone with more experience tell u that, but i was thinking it was yellow. good luck.
edit- i just looked up the installation instructions. the yellow wire is the memory wire. make sure it is getting a constant 12v source. this should fix your issue. here is the link where i found the installation instructions. once u click on installation manual, its on page 6.
http://www.pioneerelectronics.com/PU...P4200DVD?tab=D
Old Jul 26, 2010 | 05:53 PM
brickloaf's Avatar
damn i think your right, my yellow wire is hooked up to a wire with a inline fuse that best buy put in when they installed my first HU and i thought it was constant but now im guessing its switched so im gunna check it in a sec
yup that was it, thanks!
any idea on why i cant play videos even though there converted to divx?? the screen just stays black when a video is suppose to be playing but the music plays
Old Jul 26, 2010 | 09:57 PM
iboost's Avatar
Are you bypassing the ebrake thing to watch videos? If so, how are you doing it?
Old Jul 26, 2010 | 10:46 PM
reaper89's Avatar
take the ebrake wire off the h/u and put it to a toggle switch, then run another wire to a ground for the other part of the switch.
Old Jul 26, 2010 | 11:10 PM
EmperorJJ1's Avatar
right but if it wasnt bypassed propperly then it would show the ebrake warning not a black screen
Old Jul 26, 2010 | 11:17 PM
brickloaf's Avatar
yea it is bypassed. what happens is i turn the HU on and go to DVD and i toggle the switch to get past the warning screen, press OK and all that and instead of the screen turning blue, it turns illuminated black like there should be a video playing
it is bypassed tho, it goes from the HU to a switch to ground
Old Jul 26, 2010 | 11:18 PM
EmperorJJ1's Avatar
right right im not sure why the video isnt playing but the black sceen means its a problem with either the format or file or the screen itself
Old Jul 26, 2010 | 11:20 PM
brickloaf's Avatar
damn maybe it is the screen or something cause even when i put in a actual DVD like super bad or something it does the exact same thing
Old Jul 26, 2010 | 11:31 PM
EmperorJJ1's Avatar
it could be possible. then again maybe its just a setting and with no constant memory you cant really "set" the deck
ive never seen that happen so i wouldnt loose hope. best thing to do would be to wire up the constant correctly and double check any other wiring. then reset the deck and go thru all the settings to see what you see. if nothing then maybe e-mail pioneer.
Old Jul 26, 2010 | 11:34 PM
brickloaf's Avatar
yea there are some video settings but most of them are for the video outputs for other monitors and what not
im gunna take another look through the manual but yea it would be nice to play my music videos
i pulled this out of the manual
DivX is a compressed digital video format created by the DivXŽ video codec from DivX, Inc. This unit can play DivX video files recorded on CD-R/RW/ROM and DVD-R/RW/ROM discs. Keeping the same terminology as DVD video, individual DivX video files are called “Titles”. When naming files/titles on a CD-R/RW or a DVD-R/RW disc prior to burning, keep in mind that by default they will be played in alphabeti- cal order.
Official DivXŽ Certified product Plays all versions of DivXŽ video (including DivXŽ 6) with standard playback of DivXŽ media files
the videos are recorded on a DVD-R and i have it converted to a divx home theater version as a pioneer rep reccomended
Old Jul 26, 2010 | 11:51 PM
EmperorJJ1's Avatar
right right. i was just saying go thru every menu and anything that sounds like it might work hit it or change it and see what happens. almost every hu has that lil quirk that's just stupid and the only way to fix it is berried in some menu that you can only get to with a winning lottery ticket or something.
the only crazy thing i remember with the 4000 was the "reverse mode" which in the main menu you hit the reverse or some weird button in the bottom left corner. but its been a while so who knows
Old Jul 26, 2010 | 11:53 PM
brickloaf's Avatar
damn well ill take a look at it either today or tomorrow and post back what i find
riceburner
Sep 29, 2011 05:47 PM
brickloaf
Aug 3, 2011 11:50 AM
msonia03
Jan 7, 2011 04:30 PM
chevy_cobalt_addict
May 29, 2010 03:31 PM
3fo893013L
Aug 4, 2006 08:02 PM
