N2MB WOT Box Problems
Old May 14, 2014 | 08:50 AM
blackwhine622's Avatar
I recently wired up a N2MB WOT Box on my 2006 SS/SC. I went to test the box as instructed by turning the ignition on without starting the car and pushing the gas pedal to the floor. When I turn the ignition on the blue LED comes on like its supposed to but does not flash when I push the Gas to the floor. Pushing the clutch pedal to the floor does not effect the LED as well. I have triple checked my wiring and everything checks out. Also my computer cannot see the box when I plug it in even though I have selected the right COM port (COM7). Any ideas as to what could be going on? Any help is much appreciated! Thanks
Old May 14, 2014 | 08:57 AM
blueLNFftw's Avatar
How did you connect the wires?
Old May 14, 2014 | 09:40 AM
All joints were soldered and heat shrunk. All connections Ohm out.
Old May 14, 2014 | 10:02 AM
hmm i don't remember doing that test lol does the car actually start or no? it would be worth simply trying when the cars on to me. definately triple check the connection to the ecm to be sure you got the right wire though that was tricky
Old May 14, 2014 | 05:41 PM
That is what N2 suggests doing to test the box as part of the instructions. Car starts, wiring is perfect.
Old May 14, 2014 | 05:58 PM
advise's Avatar
You have to check a box in the programing to reverse the pedal output
Old May 14, 2014 | 06:26 PM
I would do that but my computer can't find the WOT box. It won't let me check any of the boxes or make any changes.
Old May 14, 2014 | 06:28 PM
REDi DEViSTATOR's Avatar
Can't find the box? Reinstall driver software.
Old May 14, 2014 | 07:54 PM
Tried that.
Old May 15, 2014 | 05:06 PM
Ok, so this may sound dumb but, make sure your key is on before you try to find the driver/box. It won't work with no power to the accessories.
Old May 15, 2014 | 08:53 PM
Yep ignition was on.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
ineedacobaltss
Nov 7, 2015 02:25 PM
dennis69
Oct 20, 2015 04:49 PM
c_m_shooter
Sep 27, 2015 04:40 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
