Nav System
Hello,
I just ordered a nav system to go with my Jensen VM9224 DVD receiver. I have the receiver already installed. The reciever is not XM compatable, but my factory radio was. So here is what I'm wondering.
How easy would it be to use/ replace the stock XM antenna with the antenna for the nav / gps reciever?
Jensen NAV104
I have a Cobalt SS/SC Coupe 2006.
Jensen NAV104
it might be possible. if you have the shark fin its probably alot more possible but really ti depends on how much u really want to do it. chances are your aftermarket nav receiver antenna has an ungodly large connector and the hole in the roof for the wire is small. so there's a good chance ur going to have to drill out your roof. buy a unibit or cheap unibit rip off from harbor freight sears ect)
Project for tomarrow!
http://www.***************/forums/au...arket-gps.html
Put yourcobalt dot com in place of the asterisks
I dont have that style antenna but I'll see what happens.
Maybe I can just swap out the stock antenna with the one that came with my nav system. I may have to put RTV around it to seal it but it SHOULD work. We'll see tomarrow when I try.
