Need to find a speed pulse sensor wire?
Old Jun 10, 2006 | 11:08 PM
Taro's Avatar
HELP Need to find a speed pulse sensor wire? HELP again
Im installing my nav system and cant find a speed pulse sensor wire, any help would be greatly appreciated.
Old Jun 10, 2006 | 11:44 PM
zinner's Avatar
Moderator Alumni
I got this from another member in a PM.
Ah its working I did get the right wire it just took awhile to sync up. It was the green/white wire going to the gauges... its pretty damn sweet the avic has a digital speedometer gauge that it displays on screen.
Old Jun 11, 2006 | 12:11 AM
xtremeGM's Avatar
Yeah thats the correct wire. I used that one also.
Old Jun 11, 2006 | 02:28 AM
Taro's Avatar
By gauges do you mean the climate control? Like the a/c and stuff? Because theres a green/white wire that goes to the old radio as well as one that does to the DIC buttons.
Old Jun 11, 2006 | 03:18 PM
Taro's Avatar
Well sorry but that wire into the controls isnt the VSS wire, im outa luck here ive tried numerous wires with no prevail. Ive tried the green/white that goes to the speedo and the DIC and nothing still says its not connected. My car is in pieces right now i need help badly.
Old Jun 11, 2006 | 10:18 PM
xtremeGM's Avatar
The wire that is the green and white wire that goes into the speedometer cluster is the right wire. Thats the one I used for my avic-d1 did you tell the sensor to reset and give it time to calibrate? Its not something instant at least it wasnt on my pioneer it took driving around for quite awhile then it finally callibrated and havent had a problem since.
Old Jun 12, 2006 | 12:32 AM
Taro's Avatar
Yah i have found my error, i never gave it enough time to calibrate, what threw m off was when i first connected it my car on the screen wouldnt stop moving and just drove off into the distance, while the reall car was in my garage :P also i have found several other wires that have VSS, B9 in the radio wires seems to have it as well, it the Low speed GMLan wire i believe and is green of sorts.
Old Jun 12, 2006 | 12:36 AM
repoman's Avatar
Do any of you have the onstar hooked up to your Pioneer units?
Old Jun 12, 2006 | 08:59 AM
sunrise_mj's Avatar
on the avic, you really dont have to hook up the wire... if you just reset the system itll figure it all out...
Old Jun 12, 2006 | 01:00 PM
Taro's Avatar
Yeah the alpine one works without the wire as well, but will work alot better with it hooked up. Plus i want all the features you get when its hooked up.
And I didnt get onstar in my vehicle.
Old Jun 13, 2006 | 11:27 AM
xtremeGM's Avatar
I found with mine it wasnt very accurate without it hooked up.
No I dont have onstar.
Taro-Glad you got it working!
Old Jun 13, 2006 | 12:50 PM
Taro's Avatar
Ok well after talking to lots of people including My dealer and there machanics, i have found the actull VSS wire. I have tried all the wires behind the speedo and none are a true VSS wire, one gives a speed rating but its not accurtate. The only really VSS wire goesinto the ECU and its yellow at pin 18. Most GPS units work without it anyways so i havnt hooked mine up yet, hopefully oneday i will.
DarrenGC
Dec 24, 2021 01:55 PM
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
dennis69
Oct 20, 2015 07:39 AM
Extremespeed
Sep 29, 2015 04:34 AM
jmelton327
Sep 26, 2015 10:04 PM
