need help with after market setup
Old Dec 18, 2011 | 11:26 PM
EN1(SW) Kirby's Avatar
So it took me and a friend a couple of days to get this system in and we landed with the sub not working. Sub does work we tested it and all and are figuring it may be the amp so im going to take that in tomorrow to get tested. The thing i am stuck on now is the Pac steering wheel adapter i read that the black/white wire is the controls and they need power so i went ahead and hooked it up to my read wire powering my h/u and my gm lan thing. But when it was hooked up to it, started to blow the radio fuse. the sound system is all brand new so im guessing the fuse cant take anymore then it already has? if so is there another place to put the black/white wire at so i can get this power to the pac so i can have my steering wheel controls. help would be greatly appreaciated.
Old Dec 19, 2011 | 05:17 AM
EmperorJJ1's Avatar
um u read its the red and black wire where? are u reading the instructions? it shouldnt be blowing fuses at all
Old Dec 19, 2011 | 11:23 AM
ya on the pac i have the ground, grounded with with the radio and the green on the blue wire on connecter 1 and the red wire spliced with the red wire on the radio to the harness so 3 wires there i tried to add a 4th wire the black and white one there.
Old Dec 19, 2011 | 11:31 AM
id say post a picture of the diagram ur reading and if possible the wires you connected... always makes this kind of stuff easier. if all else fails, check all ur sodders/connections
Old Dec 19, 2011 | 11:43 AM
ya that is true, my main question is can I tap the black/white wire to the red wire or no?
Old Dec 19, 2011 | 04:36 PM
EmperorJJ1's Avatar
if thats what the instructions say to do. if all else fails call up pac
RaginChopsuey
Oct 27, 2015 01:27 PM
patooyee
Oct 15, 2015 05:11 PM
ThoR294
Oct 4, 2015 08:44 PM
cw383
Sep 30, 2015 12:41 AM
anotherslowlnf
Sep 29, 2015 03:52 PM
