Need wiring help for a light
Old May 21, 2010 | 12:35 AM
redcobalt07's Avatar
Ok I have an aftermarket sidemarker light on my car. It's a simple two wire hook up for the light to come on. Positive and negative. Well I can wire the light to come on with the taillights or flash whenever the turn signals come on. It's one or the other. Well my question is how can I wire the lights so that they are one steady with the taillights and then when I engage the turn signals, they flash. But when I stop the turn signals they go back to being steady on for the taillights. How do I wire that?
Old May 21, 2010 | 02:02 AM
Hart's Avatar
I would figure.out which wires.do that on the rear tails n tap into them. Seems to me there should be.three wires +.-. And the blinker wire
Old May 21, 2010 | 02:20 AM
well yes but this new light only has two wires
Old May 21, 2010 | 02:25 AM
mrsilent13's Avatar
using diodes and resistors can accomplish this...add a resistor so when its steady on its slightly dimmer...and then add a diode to the wire that will blink and when it blinks it will blink full bright
Old May 21, 2010 | 02:41 AM
that isn't exactly what I wanted, i know the setup if it did have a high and low mode like the stock taillights but I wanted it so that the taillights were on, then when the turn signal was on the light blinked
Old May 21, 2010 | 02:47 AM
mrsilent13's Avatar
hmmm for some reason i cant think of how to do that setup....im sure someone will pop in real soon....wow...i cant believe i cant think on how to wire that
Old May 21, 2010 | 08:06 AM
NCC-2000's Avatar
I can probably figure out a way to do that but when it flashes it'll be backwards with the signals, so when the signals flash bright the light will be off, and when the signal is on the "off" flash it'll flash on. Have to use a relay to do this though. I can't think of an easy way to do it so that it flashes in sync with the other signals and still come on with the tails. Forcing a high/low mode would actually be easier, since that would just require some diodes and resistors, and the flashing will be in sync. The sidemarkers I installed on my fenders are just tapped into the front turn signals for simplicity.
Old May 21, 2010 | 12:37 PM
mrsilent13's Avatar
it does seem like diodes and resistors would be the easiest way to do it
Old May 21, 2010 | 08:17 PM
so do you know how to wire it with a relay? even if it does blink opposite the stock turn signals
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
dennis69
Oct 20, 2015 04:49 PM
dennis69
Oct 20, 2015 07:39 AM
ernnyyes
Oct 2, 2015 05:16 PM
jmelton327
Sep 26, 2015 10:04 PM
