Negative Resistance?
Old May 23, 2009 | 09:37 PM
Ishbar's Avatar
I believe that is the proper term, correct me if wrong though!
I was curious about the 12v Adapters in the Cobalt and what you can or cannot leave in them, and if they provide some sort of "Negative Resistance" when the device is not demanding power (So the battery does not drain)
Thoughts, Questions, Ideas?
Old May 24, 2009 | 12:10 AM
EmperorJJ1's Avatar
there is no such thing as negative resistance.
what 12v adapters are u talking about? wiring harnesses for the radio?
Old May 24, 2009 | 12:15 AM
Ishbar's Avatar
No.
The Cigarette lighters.
IDK what the V is, but I assumed 12.
Old May 24, 2009 | 12:17 AM
jlong3382's Avatar
If there is not a complete circuit, current will not flow.
Old May 24, 2009 | 12:19 AM
EmperorJJ1's Avatar
V is volt. 12v is a basic term for car electrical. example pioneer car audio is a 12v company
im pretty sure the cig lighter is constant power so as long as the unit is plugged in its on
Old May 24, 2009 | 12:40 AM
Ishbar's Avatar
I guess what Im getting at.
Is it bad to have **** plugged in?
I have my GPS plugged in even with my car off, but that is just the charger.
I take the unit itself off.
Another example would be an iPod charger.
Old May 24, 2009 | 12:47 AM
nicksredline's Avatar
as long as it is not charging the pice it will not take enough of the voltage to not let the car start unless it is like 2 weeks of pure sitting...( i leave mine in all the time... its like ur radio( it kinda stays on it has to to keep the time on the clock or elce when u shut ur car off if its 2 it will stay 2 untill u turn it back on) u should be just fine.
BTW: its called parasitic load( drain on a sorce most of the time referd to on a 12V sorce)
Old May 24, 2009 | 01:24 AM
EmperorJJ1's Avatar
i leave my cell phone charger plugged in.... charging my phone at times too. as long as your not going crazy you will be fine
Old May 24, 2009 | 12:30 PM
oowah's Avatar
Does the cigarette lighter not turn off after 20mins of the ignition being off? I've never tested it, lol or put any thought into it, but I thought that was how it worked. Like part of the battery run-down protection, where your lights turn off after 20mins or so.
Solaris99
28
Mar 15, 2017 01:22 PM
mkulrey13
How to Guide
157
Apr 17, 2013 01:58 AM
