Neutral Safety Switch-Remote Start
Old Dec 21, 2008 | 01:45 PM
Unforgiv3n's Avatar
So my roomate was installing a Security/Remote start in my 2006 SS/SC and he realized there is no Neutral Safety Switch. I thought this was really odd. The option to get it to work correctly would be to install a switch to the button on the clutch so i can disengage it while driving so i can still use my cruise control. Thoughts on this.. good or bad idea? Besides the safety part of accidentally leaving the car in gear any other things we should be aware of?
Old Dec 21, 2008 | 02:41 PM
REIGN SS's Avatar
Original Hayden Fanatic
Not installing a Remote Start on your Manual Transmission car would be the Safest Part...
Old Dec 21, 2008 | 02:49 PM
INFE's Avatar
I was thinking of doing this on my car as well. Did you find a kit that would work for the SS??
Old Dec 21, 2008 | 04:46 PM
ptrblkz24's Avatar
Why?There are remote starts designed for manual transmissions.
As for bypassing the clutch,its easy.Your gonna have to wire up a relay to energize the clutch wire in order for it to start.No need to install any switches on the clutch switch.I hope your friend knows what hes doing cause installing a remote start on these cars is not easy.
Old Dec 24, 2008 | 02:25 AM
KyFritz06SS's Avatar
A remote start on a manual car is Illegal in some places. By law you are not allowed to have one. You better check that out. Its prob. not the safest thing to do so be carefull.
Old Dec 24, 2008 | 02:33 AM
Acey's Avatar
Of all manual transmissions guys, those on this board should be the ones not thinking of doing this cause it means parking in neutral, and with the shitty e-brakes in Cobalts you wanna not park in gear? No thanks.
Old Dec 24, 2008 | 02:52 AM
EmperorJJ1's Avatar
lol i normally park in neutral. mainly a habit thing. Im getting better but not by much
Old Dec 24, 2008 | 03:13 AM
ls1fbody's Avatar
Haz l33t wheelz.
i park in neutral as well, if someone hits me, it doesn't break things in the car. that being said, its habit as well, probably a bad one, but i check me e-brake, and have it inspected every other month just about.
Old Dec 24, 2008 | 03:28 AM
impulseballer's Avatar
i think compustar or some other company makes a remote start pager system specifically for manual. you must have the car in nuetral and have the ebrake up before you turn off the car or the remote start will be disengaged. i'm getting one for my next car for sure.
Old Dec 24, 2008 | 03:38 AM
raptors_67's Avatar
I Install compustar and have done so in a number of manual transmissions as well as had mine for over 2 years (as long as I've owned this vehicle). These are some of the easiest vehicles in terms of dealing with the clutch..... if you want more info I can be specific but I don't want to see anymore posts about stupid push buttons or whatever ideas the uneducated people that feel the need to post are talking about...
You should be very fearful of letting your roomate continue to work on your vehicle especially if he came up with this switch idea.
Last edited by raptors_67; Dec 24, 2008 at 03:40 AM. Reason: Automerged Doublepost
Old Dec 24, 2008 | 03:44 AM
so how is compustar's system....is it safe etc.
Old Dec 24, 2008 | 11:28 AM
Spun's Avatar
I have the CompuStar Pro P2W9000FMR
Its a bit of a bitch to get to work on the 07's but other than that it rocks.
The Canadian version has longer range than the US model (4500 feet compared to 3000 feet) so if you can see if you can get the international model
Your going to have to force it to learn the tach, and make sure you get the november 28 update for the idata link modules or its going to cause issues going into reservation mode
Old Dec 26, 2008 | 12:05 AM
EmperorJJ1's Avatar
what a canadian version? damn i need that then
Old Dec 26, 2008 | 02:52 AM
raptors_67's Avatar
You have to "force" every compustar to learn tach.... lol unless you're going to use voltage sense or one of the other engine running detection modes.... you're just asking for problems using these other methods, go to an injector wire or even one of the coil packs for your tach signal (injector wire is preferable in cold climates... more consistent at varying temps). Not sure what update you're speaking of, If there was an update on the 28th I havent put it on mine as it's been in the car for over 2 years now. The 07's are actually an easier install than pre 07's.
I sell the Canadian versions.... had no idea about the range difference but I have heard the US was not allowed to operate on the same frequency as Canadians for these starters.
Last edited by raptors_67; Dec 26, 2008 at 02:52 AM. Reason: Automerged Doublepost
Old Dec 26, 2008 | 02:54 AM
EmperorJJ1's Avatar
lol want to install it for me too? im gonna see what all i can do this yr at ces hopefully pick em up
Old Dec 26, 2008 | 02:57 AM
Spun's Avatar
Its actually called the "international" model, but since we don't get very many Euro or Mexican posters here I figured it mainly applied to Canadians, but yeah any where out side the US.
The numbers on it are 1500 meters compared to 3000 feet
So 3.33 feet to every 1 meter, 1500x3.33= 4995 feet.
Don't get me wrong 3000 feet is still a good distance but close to 5000 is much better, even without the remote start the added distance for the 2 way paging system is an added bonus.
Its not often that we Canadians get the better end of anything so I guess we take them where we can get them
ericgt79's Avatar
your not suppose to park in neutral?
Old Dec 26, 2008 | 03:10 AM
Spun's Avatar
I stated before that security is just not my area of expertice, stereo's I know alarms are like the dark side the moon for me. I do know what problems they had installing mine so thats the info I passed on
I just had mine updated, so check Idata link or Compustar support for the update, other than I can't tell you much.
I am however blowing fuses for the remote start left right and center, and as much as I love the guys who did my stereo work they kinda screwed the pouch on this alarm, any idea's on why i'd be blowing fuses.I'm sure its an install issue but what part of the install would do this
Also there is an issue with a voltage drop in one of the modules around the ignition, its supposed to put out 12 but it cycles anywhere from 3-9 volts sometimes. Have you every run into this problem and if so how did you fix it
BTW- I think they did go to the injector wire but tried the other way first this is what caused the issue with the forced tach
Old Dec 26, 2008 | 03:17 AM
EmperorJJ1's Avatar
not really. i actually had my old camaro roll out in the road in the middle of class when i used to go to college. felt weird be called on the intercom like in high school
any chance you can pm me a price?
Last edited by EmperorJJ1; Dec 26, 2008 at 03:17 AM. Reason: Automerged Doublepost
Old Dec 27, 2008 | 02:28 AM
raptors_67's Avatar
I'd be willing to bet that they are blowing fuses because they are trying to trigger a start as you would do with pretty well every other vehicle out there, you dont need to do this on the cobalts. These cars actually do not have a wire that goes 12volt to trigger the starter to crank (as im sure everyone has noticed they dont have to hold the key forward to start the car) . These cars actually start after the ignition wire goes from 12 volts to 0 volts at the column. I can't recall if the 06 and previous years are the same but I know the 07's are for sure.
I will PM you a price tomorrow if I remember to look it up at work. I would have to order one in for you which takes a few days as we've been goin crazy on sales of these 2-ways since it's such a cold winter here this year.
Last edited by raptors_67; Dec 27, 2008 at 02:28 AM. Reason: Automerged Doublepost
Old Dec 27, 2008 | 02:33 AM
jefferyss's Avatar
the neutral saftey switch your refering to .......is your clutch pedal !
just in case no one has pointed that out to you
Old Dec 27, 2008 | 02:51 AM
EmperorJJ1's Avatar
its all good im not planning on spending any unnecessary money before ces.... theres going to be a 5.1 audio booth again and last year i just happened to pick up 2 disks (whihc was all i could really afford) this year im planning on having enough to get as many as i want. I probably wont find anything special but hey they might have the missy album
Old Dec 27, 2008 | 12:43 PM
ptrblkz24's Avatar
Yeah,my 06 is like that.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 04:49 PM
DocSvensk
Sep 27, 2015 02:24 PM
