new amp with stock alternator.
Old Dec 4, 2007 | 04:02 PM
cobaltss4u2env06's Avatar
I have the stock alternator...which i think ids 75 amps. I wanted to buy a new amp that would push around 1000 watts. But they say that you have to upgrade your alternator to like a 200 amp alternator. Has anybody isntalled a sound system that exceeds 1000 watt amp...and had to change there alternator?
Old Dec 9, 2007 | 11:24 PM
David12460's Avatar
Im curious about what people have done with "bigger" sytems too....
Old Dec 9, 2007 | 11:26 PM
EceSSiveMod's Avatar
i had 1500 watts on a 9 year old cavalier alternator. U can upgrade but its not gonna do anything if you dont besides the lights will dim a little bit whenever it hits real hard but thats about all
Old Dec 9, 2007 | 11:31 PM
BlackWidowSS07's Avatar
I have 2 1500 watt subs running in my car on the stock alt and its running fine.
if its a major concern just keep the gain turned down and you'll be fine
Old Dec 9, 2007 | 11:33 PM
halfj99's Avatar
yeah i had about 1200rms to my old L7 and it was fine
Old Dec 9, 2007 | 11:43 PM
sick06cobalt's Avatar
I have an 800 watt t8002 you should be fine....
Old Dec 9, 2007 | 11:56 PM
David12460's Avatar
Not to jack the thread but if i run both these amps i should be cool?
http://www.sonicelectronix.com/item_...ZXi+4006.html#
http://www.sonicelectronix.com/item_...BXi+1206D.html
Old Dec 10, 2007 | 12:48 AM
cobaltguy88's Avatar
I have a 1000 watt amp with 2 mtx subs that are 500w each running on stock alt... its going good now, havent had any problems.
Old Dec 10, 2007 | 12:52 AM
you'll be fine man. ill put it to you this way, a good way to know when you need to upgrade the alt is when you start running 0 gauge for your power and ground. you'll be fine
Old Dec 10, 2007 | 08:35 AM
Cobalistic's Avatar
I use 0gauge power and ground for my 2000 watts and everything is fine. Also using a yellow top and cap.
Old Dec 10, 2007 | 01:46 PM
MTXSS's Avatar
You need power to make power. Doesn't matter how much power if you unless you have the back up power necessary to perform correctly. But to answer you question, yes you can. You may occur problems down the road but a average 1000 watt amp will pull about 30 amps of current. Usually i would say purchase a 1 farad cap after 800 watts. anything exceeding the 1500 watts "true power" i would just go with a additional battery cuz a cap isn't going to do much. Going back to what I said ealier, it's going to eventually weekend. You wont see any issues till down the road. Pending on why you are looking at 1k power? it's to be determin. What do you have in mind?
Old Dec 10, 2007 | 01:48 PM
ExcentricK's Avatar
yeah i have a 1300 watt stereo system and i definatly need a new alternator!! Its really bad!! I push the window button and my lights dim down sooo much!!
Old Dec 10, 2007 | 01:58 PM
slowbalt19's Avatar
a battery is nothing more than a rather large cap, when the car is running its purpose is to help smooth out the ripples from the ac to dc conversion from the alt. If you are going tho run a system big enough for a second batt you should just upgrade your alt since that is what is supplying the power, not the battery.
Supercharged06SS
Dec 11, 2022 04:47 PM
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
Oct 13, 2015 09:32 PM
Stuff
Oct 1, 2015 05:47 PM
c_m_shooter
Sep 27, 2015 04:40 PM
