New Head Unit
https://www.cobaltss.net/forums/electronics-audio-video-49/aftermarket-install-faq-79043/ theres the FAQ that has been stickied
I got one from Besy Buy. I have everything connected, including the red to the red on the steering column for power, but some people are saying that the stock amp overrides it i guess.
The only wire on the harness not connected to the same color is the blue remote wire. people said that it would work if i plugged it intothe blue with white cord but i stillget no sound. Radio works no sound. I hate this setup. It's got to be something with the factory amp.
u need the remote wire from the sony to hook up to the stock amp. Look on your stock harness.... on the actual car harness part and find the PINK wire. It should line up with the blue wire on the "car harness" u bought and hooked up. If not you will need to some how connect that wire with ur blue/white remote on the sony harness. I dont really recommend cutting ur harness but what u do is up to u
Thanks, I finally got it work after a trial and error process. I needed to connect the grey (amp) wire, (thats what it said on it), from the aftermarket harness. The only thing i can't get to work is the steering wheel volume controls. (didn't put much time into that b/c it got dark out). The only wire not connected to something on the aftermarket harness is the blue (remote) wire. I really don't know what i'm doing, but i guess thats how we all learn. lol
if u get the module then yes
Last edited by EmperorJJ1; Jun 26, 2008 at 08:52 PM. Reason: Automerged Doublepost
agentirons
Oct 16, 2015 02:11 AM
Sep 28, 2015 12:51 PM
