Newbie Needs Help! Turn Signal Flasher
Old Jun 15, 2006 | 06:25 PM
njloki30's Avatar
I'm trying to wire some peel and stick arrow turn signals that mount to my sideview mirrors, but I dont know where the flasher is two splice into the tun signal. Its the same bulbs as the daylamps, and I don't know where to jump into so that the arrow blinkers dont stay on constantly, and blink when I put on my tun signal. Any one want to take a stab at this question would be greatly appreciated. Thanx in advance.
Old Jun 15, 2006 | 08:26 PM
mkulrey13's Avatar
Why is this is audio/video? anyway try running it to the fuse in the fusebox for the blinkers?
Old Jun 16, 2006 | 11:34 PM
njloki30's Avatar
I posted it here cause this is the only topic with electrical wiring, as per the main page. The manual doesn't list which fuse is for the blinkers. That was orignally my plan.
Old Jun 16, 2006 | 11:42 PM
bredick's Avatar
fuse would be no good either, how about either the indicator wires in the instriment panel or running wires to the rear lights? or if you want to go to the flasher module it's probably in or near one of the fuse boxes, either unnder the hood or in the cabin.
Old Jun 17, 2006 | 02:53 AM
CobaltCoupeCrazy's Avatar
GOOD LUCK, finding a flasher. If you do find it, be sure to let everyone know. We need to install a different one to run LED lights without increasing turn signal flash rates.
Also, taping it into the rear lights would cause the mirror signal to light up with the brakes as well.
Old Jun 19, 2006 | 07:02 AM
njloki30's Avatar
I"m probably gonna run the wire right to the headlamp, there are three wires only one is going to cause that second filiment to come one, I guess I'll put a tester on them to see whats what. I can't find the flasher, I'm pretty sure its tied into the hazard switch, which is way under the dash I think ans not worth trying to get to when I can most likely get these things working by going directly to the headlamp
Old Jun 19, 2006 | 09:46 AM
Bandit2941's Avatar
Try it but I'm not sure if that's going to work either, since the front blinkers are the same lights as the daytime running lights. If you do that, you'll probably end up having the turn signal lights come on with the DRLs.
Old Jun 19, 2006 | 10:14 AM
fljohnboy's Avatar
I guess all you have to do is find this. I imagine it's in steering column somewhere.
Old Jun 19, 2006 | 09:57 PM
bredick's Avatar
Although it is one bulb it is 3 or 4 wires, they have 2 filiments, one for brake and one for turn signal, at least that's how most single bulb setups I've seen are.
Old Jun 19, 2006 | 10:04 PM
mike25's Avatar
lol wtf wrong section...and why the hell do u want arrow stickers on your mirrors?...
06MetallicBalt
Jul 20, 2025 08:47 PM
Solaris99
28
Mar 15, 2017 01:22 PM
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
roth
Sep 26, 2015 12:16 PM
