Noob Electrical Question
Window Licker
Im installing my wideband, I already have my interceptor gauge powered via tap of the boost gauge power wire, is it ok to tap my wideband gauge into that as well or should i find a different source? wasnt sure if having 3 things connected to that was alright?
Check the fuse rating of the circuit your taping into and add up the draw of all of the items your hooking up to. If the draw is more than the fuse find another circuit or up the fuse size to accommodate. You should be fine since most gauges usually draw less than an amp.
