Pioneer AVIC 700BT Issue
Old Jun 18, 2012 | 10:29 AM
gonzmexican's Avatar
Hey Guys,
I have had my Pioneer in-dash unit for a few years now and it has work great! Last month however I ran into a bit of an issue. The splash screen appears for a few moments then goes blank (it is still backlit however, it is a lit black..not "off" black as if it was turned off). I have my ipod hooked up so I can still listen to music but I have no control over nav, music (radio, cd, switching between), or any other functions since I cannot control the screen.
Has anyone had this issue with a pioneer and if so, how did you fix it?
Thanks!
Old Jun 18, 2012 | 12:04 PM
mufinman007's Avatar
it sounds to me like the back light is going out or out all together . i would check the ribbon cable that goes to the face or to the main bored . and make sure it not pulled out or at a angle that will cause the screen to go dark
Old Jun 19, 2012 | 04:25 AM
EmperorJJ1's Avatar
either backlight or setting issue. if i remember correctly there was something stupid u could enable that would cause that. id call pioneer first see what a tech says just in case otherwise yank the power on it and let it sit for 5-10 mins restart and see its either going to fix the problem or the reset will prevent it from going to ipod automatically
Old Jun 19, 2012 | 04:45 AM
cuebalt's Avatar
if i recall my headunit does the same thing if i turn on the rear view camera setting withought a camera hooked up, like emp said disconnect the battery for a bit and it should fix it
Old Jun 19, 2012 | 02:04 PM
cool thanks for the input guys i'll call over the pioneer this weekend!
Old Jun 21, 2012 | 09:55 AM
cobalt blue's Avatar
I had a similar issue, and found that the rear view camera was set to on and I do not have the camer installed, some how it got turned on, once I turned it off the unit worked ok.
Old Jun 21, 2012 | 12:10 PM
^ but how do you set it to off if the touch screen is not working? I will call them over the weekend!
Old Jun 22, 2012 | 01:57 AM
EmperorJJ1's Avatar
ya never figured that one out. reset works thou
Old Jun 22, 2012 | 09:27 AM
^ ok so get this. I when the screen has gone blank, pressing any menu or map button has never worked. This morning I got up for work and turned on my car, screen went blank per usual, I hit map about 10 seconds after, and the screen turned on! I went directly to the rear view camera setting and it was on so I turned it off and EVERYTHING WORKS I shut my car off and turned it back on just to make sure and it looks like I am golden! thank you guys for the tip!
Jan 12, 2016 12:01 AM
Trav3480
Oct 1, 2015 08:17 PM
Tupp
Sep 30, 2015 08:18 PM
nathan112i
Sep 30, 2015 07:12 PM
Sep 27, 2015 08:53 PM
