pre amp outputs?
Old May 26, 2010 | 08:32 PM
harryresh's Avatar
pre amp outputs?
i have a 4 channel amp for my speakers. I was wondering if i'm going to have to buy an aftermarket head unit w/ pre amp outputs or is there something i can do w/ the stock unit to compensate?
Old May 26, 2010 | 11:59 PM
badboyz778's Avatar
go to your locate audio store and get a line in converter you have to bite in to the rear speakers to this unit that converts speaker signal to rca signal wire the amp and off you go
DeepBlack SS's Avatar
This
Old May 27, 2010 | 01:00 AM
fryedaddy's Avatar
Do you have the standard system or the Pioneer?
Old May 27, 2010 | 01:09 AM
EmperorJJ1's Avatar
right you would need 2 line output converters (front and rear) but going aftermarket is a better idea. Fryedaddy asks a good question thou bc if ur amping the stock pioneers your going to have some issues
Old May 27, 2010 | 03:47 PM
harryresh's Avatar
alright, i got a LOC. it has 2 white and 2 grey wires coming out...which set is for the right speakers and vice versa? do i have to disconnect the wires feeding the front and rear speakers right now and connect the rear speaker wires to the LOC, and then run the wires off of the amp to the front and rear speakers?
Old May 29, 2010 | 10:36 AM
harryresh's Avatar
Old May 29, 2010 | 10:55 AM
EmperorJJ1's Avatar
the white is left the gray is right. you want to tap into the wires but leave them connected so the speakers still work. this needs to be done after the amp so at the back speakers and either at the amp or kick panel or whatever for the fronts
Old May 30, 2010 | 09:35 AM
harryresh's Avatar
ok. def didnt understand the second sentence. if u leave the speakers connected, what do you hook up the wires to that r coming out of the four channels of ur amp?
Old May 30, 2010 | 10:24 AM
EmperorJJ1's Avatar
sorry your right... got confused with doing a sub amp
The Rookie24
Jan 20, 2016 05:14 PM
toysareforboys
Nov 17, 2015 05:22 AM
chefhhr
Oct 26, 2015 10:36 PM
c_m_shooter
Sep 27, 2015 04:40 PM
