Problem after install of avic D3
Old Dec 28, 2009 | 02:36 AM
SC cobaltss15's Avatar
Okay so yesterday i installed the avic d3 into my 2008 cobalt ss tc... everything seemed to work fine. Today i turned up the volume all the way and it only sounds abbout half of what the stock system was putting out. I was always told with an aftermarket head unit it should be louder. Is this normal or is it that i wired it wrong. I mean it seems to play fine, just not as lloud as the stock system would go.
thanks sam
PS: also i used the Gmos lan-04 connection for my cobalt because of onstar.
Thanks again Sam
Old Dec 28, 2009 | 02:41 AM
ssweeet's Avatar
thanks sam
Thanks again Sam
i had mine professionally installed. i don't have onstar, but i had to get a wire harness for my car as well. this isn't normal. i am not knowledgeable enough to know how to solve your problem. sorry.
Old Dec 28, 2009 | 02:49 AM
ecotecon18s's Avatar
have you adjusted the sound settings? after a little tweaking I hardly get mine up over 13 because it is so loud...
Old Dec 28, 2009 | 12:39 PM
yes i have adjusted sound settings.... the only thing i have found is someone said there is a screw that needs to be tightened that adjusts the loudness level. Havent found that screw yet! Any help?
Old Dec 29, 2009 | 03:21 AM
EmperorJJ1's Avatar
its on the gmlan module itself. the module is a black case with 2 harnesses and a knob on it somwehre. u cant miss it
Old Dec 30, 2009 | 12:32 AM
07blackss86's Avatar
This, but be warned, if you turn up the volume on the box you are going to be turning up the volume on the door chime. When I did mine the chime pissed me off until I ended up bypassing the factory amp for my 4 channel
turbochargedss2012
Sep 20, 2023 12:17 PM
dennis69
Oct 20, 2015 07:39 AM
justinchinn
Oct 2, 2015 12:18 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
