problem with capacitor
Old Jul 2, 2008 | 06:01 PM
SS4speed's Avatar
I have a tsunami 5 farad capacitor hook to a kicker amp 1500x1 and 2 kicker L5's. the problem is the capacitor will make the amp cut on and off when the bass hits hard. I bypassed the capaitor and everything works fine. that is how i know it is the problem. what could it be?
Old Jul 2, 2008 | 06:05 PM
Area47's Avatar
Rent me! per hour
get rid of the cap. period. end of story.
Old Jul 2, 2008 | 06:08 PM
Installer1's Avatar
Either the cap is defective or the internal connections (where you screw the wires into the cap) are loose from the body of the cap.
If you can wiggle the pos. or neg. or both blocks that you connected your power and ground to, that might be it.
Old Jul 2, 2008 | 11:20 PM
EmperorJJ1's Avatar
normally those shitty caps are just that. throw it away.
Old Jul 3, 2008 | 04:33 AM
dakotaspeir's Avatar
#cobalthoes
Just get a better battery.. and toss the cap
Old Jul 3, 2008 | 04:56 AM
TeDy's Avatar
To actually fix your problem, you need to wire it parallel. Battery to POS side, then a wire from the POS of the cap to the amp. And of course ground off the NEG side of the cap to the chassis of the car.
Old Jul 3, 2008 | 12:30 PM
Installer1's Avatar
What?
Old Jul 3, 2008 | 03:52 PM
TeDy's Avatar
Sounds like he has it wired so the ground goes to the amp. Bass hits, power shuts off because the cap no longer has power. He said if he takes out the cap it runs fine, so the amp is fine. So its either his wiring or the cap, and I'm pretty sure, its the wiring. Because the amp wouldn't shut off if the cap was defective because it would still get power from the battery.
Old Jul 3, 2008 | 04:21 PM
Installer1's Avatar
However with the power line from the battery going through the cap first, if it were a loose connection inside the cap, this would also cause it.
I would ditch the cap regardless.
Old Jul 3, 2008 | 04:48 PM
TeDy's Avatar
x2
Old Jul 3, 2008 | 04:53 PM
colinxx235's Avatar
are you running a 0.5 farad or a 5 farad cap, and I wouldn't ditch the cap, systems destroy cobalt battery/alternator... :P
Old Jul 3, 2008 | 05:43 PM
TeDy's Avatar
Screw the alternator. Who needs that anyways?
Old Jul 3, 2008 | 06:40 PM
Area47's Avatar
Rent me! per hour
caps are good for one bass note. then they turn into big resistors.
get a bigger alternator. the end.
Old Jul 3, 2008 | 07:24 PM
colinxx235's Avatar
what would make you say that, I have a 1 farad stinger and it works amazing, no flashing lights etc... and the bass power was increased
Old Jul 3, 2008 | 07:58 PM
SS4speed's Avatar
i was running a 5.0 cap
to let you know it wasnt the wiring. i had a stringer 1.0 cap laying around and decided to try it. turns out i works with no problems. i think it is just a bad cap because i return it twice and got new a new one each time.
Old Jul 3, 2008 | 08:05 PM
colinxx235's Avatar
The problem was probably to do with the size of the cap... for what you are running 1.0 is definitely plenty. 5.0 would probably require at least 5000W++... but hopefully all works now.
Old Jul 3, 2008 | 08:09 PM
Slapnuts's Avatar
why would u use a a 5-farad cap for a 1500 watt amp? 1farad-1000watts
Old Jul 3, 2008 | 09:06 PM
-the.k.w.c-'s Avatar
i have a tunami cap and i had problems with it ..i found them to be crap so i got a stinger 10 farad all my problems were solved
Old Jul 3, 2008 | 09:09 PM
Tazmanian_Dvl's Avatar
Get a batcap. This thing is the ****!
http://www.batcap.net/
Old Jul 3, 2008 | 09:14 PM
joeworkstoohard's Avatar
good grief, is it the size of a wastepaper basket?
Old Jul 3, 2008 | 09:31 PM
SS4speed's Avatar
i wanted the overkilll LOL
Old Jul 4, 2008 | 01:16 AM
EmperorJJ1's Avatar
damn all kinds of fucked info on here...
Old Jul 4, 2008 | 01:22 PM
tsunami caps are just crap i talked to my rep and even he said they get a lot of returns on them because lots of bass messes up the insides or something he told me ........even he is using a stinger 5 farad
Old Jul 5, 2008 | 02:50 AM
EmperorJJ1's Avatar
look at the prices. a 10f cap for the same price as a good fosgate or stinger 1f? they are built like **** really. One guy at the shop is using a lanzar specifically as a d block since he was mounting his amp on the roof late at night and wanted to finish up. I told him to just grab a regular 1f but nope. Now hes having issues since its so shitty (he knows/knew from the beginning and its temp until he orders the fosgate one)
turbochargedss2012
Sep 20, 2023 12:17 PM
yellow dragon
Sep 28, 2015 09:49 PM
Iceberg
Sep 28, 2015 01:31 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
