problem with capacitor
I have a tsunami 5 farad capacitor hook to a kicker amp 1500x1 and 2 kicker L5's. the problem is the capacitor will make the amp cut on and off when the bass hits hard. I bypassed the capaitor and everything works fine. that is how i know it is the problem. what could it be?
Either the cap is defective or the internal connections (where you screw the wires into the cap) are loose from the body of the cap.
If you can wiggle the pos. or neg. or both blocks that you connected your power and ground to, that might be it.
To actually fix your problem, you need to wire it parallel. Battery to POS side, then a wire from the POS of the cap to the amp. And of course ground off the NEG side of the cap to the chassis of the car.
Sounds like he has it wired so the ground goes to the amp. Bass hits, power shuts off because the cap no longer has power. He said if he takes out the cap it runs fine, so the amp is fine. So its either his wiring or the cap, and I'm pretty sure, its the wiring. Because the amp wouldn't shut off if the cap was defective because it would still get power from the battery.
I would ditch the cap regardless.
tsunami caps are just crap i talked to my rep and even he said they get a lot of returns on them because lots of bass messes up the insides or something he told me ........even he is using a stinger 5 farad
look at the prices. a 10f cap for the same price as a good fosgate or stinger 1f? they are built like **** really. One guy at the shop is using a lanzar specifically as a d block since he was mounting his amp on the roof late at night and wanted to finish up. I told him to just grab a regular 1f but nope. Now hes having issues since its so shitty (he knows/knew from the beginning and its temp until he orders the fosgate one)
