problems with amp help
Old Jan 8, 2010 | 09:50 AM
SS4speed's Avatar
ok here's my problem i put in a aftermarket cd and amp into my 2007 cobalt ss/sc. the cd works great and the factory sub and amp still play but my aftermarket amp and subs won't. there is 11.5volts on the power side. the amp is a digital kicker amp and when i run a test the speakers play bass but not from the song. could it be my rca cable?
Old Jan 9, 2010 | 01:30 AM
EmperorJJ1's Avatar
11.5v is real real low for the power wire but it could be alot of things
Old Jan 9, 2010 | 02:43 PM
SS4speed's Avatar
will the car was off when i test it. name some off the things that could be wrong so i can check them
Old Jan 9, 2010 | 10:41 PM
Nightmare9's Avatar
"when i run a test the speakers play bass but not from the song"
Could you elaborate a bit more on that? If you are getting bass but no mid & high my first guess would be you plugged that amp into the sub port/jack on the new deck (i'm assuming by cd player you are referring to a new head unit), my 2nd guess would be some funky setting in the equalizer on the deck (ie, only sending bass on that output)
Old Jan 9, 2010 | 11:54 PM
EmperorJJ1's Avatar
i must have missed that part but if your getting bass thats not in the song. then either... your amp is broken, ur RCAs are broken or your ground isnt properly connected
Old Jan 10, 2010 | 12:51 AM
SS4speed's Avatar
ok when we play a song the music play though all the speakers expect the aftermarket subs. the amp is a kicker 650x1 and it digital and has a test section on it and when i hit that it play a test bass. so that is my question why would the test work fine be the song that i am play will not play though the subs. what i mean by the car was off is we just had the switch on and the car wasnt running.
Old Jan 10, 2010 | 01:17 AM
EmperorJJ1's Avatar
ya turn the car on...
like i said amp could be broken rcas could be broken or bad ground... If the amp is busted and its producing dc signal it will destroy you sub and quick. test it out unplug the rcas see what happens. wiggle the ground see what happens. ect i can probably get the amp fixed for u if thats the case too
Old Jan 10, 2010 | 10:15 AM
SS4speed's Avatar
k i will check it and let you know thanks for da help
Old Jan 10, 2010 | 09:37 PM
evil ss's Avatar
first off its a pioneer deck there is a setting to turn the sub rca output on and off make sure that is on. second if that is on the other test would b go buy an aux to rca wire and plug it into an ipod and the input on the amp and turn the car on if it plays the sub off the ipod then your rca is bad
Old Jan 12, 2010 | 10:07 PM
SS4speed's Avatar
it was the rca cable thank's for the help everyone
turbochargedss2012
Sep 20, 2023 12:17 PM
yellow dragon
Sep 28, 2015 09:49 PM
c_m_shooter
Sep 27, 2015 04:40 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
