Question with Stock sub
can the 10in sub be removed from the black plastic box it comes in????
i want to replace it with out haveing to add a big aftermarket box in the car
thanks guys
thanks guys
Do not take my word on this because I am not sure, but I think that if you put in another sub, I assume you would want to throw in a more powerful one. I don't think the stock amp would handle anything more than what is already there.
But I could be wrong, maybe that amp has tons of more power in storage, lol.
it can be removed, via taking the box out, there is a bold in the back that actually holds the sub in, and also the screws in the front..... it is a good sub, very heavy and dvc.... a 250 watt mono amp would make it sound 100 times better
also, it is a sub that has been built to work in that box..... if you go with a different sub, the magnet may be too deep, and it may not fit, also the box may be too small to accomidate the sub for good sound, a lot of it has to do with pressure levels, if you replace the sub in the stock box, you may actually end up loosing sound quality, and performance... also i would not run any other sub off the stock amp, as the channel only gets like 100 watts, or 75, or something....
