Radio
Old Oct 31, 2005 | 01:16 PM
undrgrndcobalt's Avatar
Radio
i have an SS/SC without xm
i have the mp3 radio tho
is there a difference in the mp3 radio with xm, and the one without. i want xm...
Old Oct 31, 2005 | 06:01 PM
SilverSS/SC's Avatar
While the circuitry in the radio itself is already set up for XM , your car is not wired for it . GM class 2 communications is rather complicated and it would be pretty damn costly to get the right wiring harness and antenna installed in your car .Class 2 communications in GM speak is Various systems in the car are tied together by a serial data line that commumicates with the various modules in the car like the Body control , pcm ect . Alot of pcm and module info , that have nothing to do with radio , travel thru it . XM if you had it , would have been intergrated into that huge bundled interior harness .
Aftermarket XM , or Cirrius ( better than XM imo ) is about the only logical option ya got man . Unless ya wanna spend ALOT of money and remove most of your interior to install .
Old Oct 31, 2005 | 09:08 PM
zinner's Avatar
Moderator Alumni
The difference is $395
There are company that make harnesses to adapt XM to XM ready radios but they are kinda pricey (I have seen 75+ for the harness) and they are class 2 only and I am 99% sure the Cobalt radio is GM-LAN and not class 2 anymore.
At this point your probably looking at getting like the XD Roady add on or doing lots of research and figuring something out on your own.
Old Oct 31, 2005 | 10:59 PM
italstalnprd86's Avatar
i got a xm roady 2 from delphi..... it has the built in fm transmiter, but it is crystal clear, i am very happy with it, and it was only like 80 bucks
Old Nov 1, 2005 | 12:00 AM
zinner's Avatar
Moderator Alumni
i checked the manual and the XM digital receiever is GM Low speed LAN (not class 2) and it should be a unit located between the two rear speakers. If you have some wiring there and no unit maybe all you need is the unit and antenna.
Old Nov 1, 2005 | 05:14 AM
Originally Posted by zinner
i checked the manual and the XM digital receiever is GM Low speed LAN (not class 2) .
Damm , I had no clue they changed . Does that mean the radio is powered by a switched 12 volt signal again ?
Old Nov 1, 2005 | 09:46 AM
fljohnboy's Avatar
I just installed a Delphi in my friends car. It works great. Got it on Bestbuy website for $49 and they give you a $25 gift card.
http://www.bestbuy.com/site/olspage....=1083713296841
Old Nov 1, 2005 | 09:52 AM
OniMirage's Avatar
i have the xm package and like it alot BUT i wanna listen to howard stern in the morning when he goes to serius ... anyone know of a conversion that can be done ???
Old Nov 1, 2005 | 10:36 AM
zinner's Avatar
Moderator Alumni
I looked into it but I could not find any way to do it on a GM-Lan vehicle.
The Rookie24
Jan 20, 2016 05:14 PM
chefhhr
Oct 26, 2015 10:36 PM
agentirons
Oct 16, 2015 02:11 AM
shawnsseries
Sep 10, 2015 08:29 PM
