Radio Help
Ok so im some what new to my car...Audio wise (its a 2007 ss s/c)
I am looking to put in a head unit like this...
Now what i need help with is im not sure of the dash kit i need and
aftermarket radio to stock radio plug...??
if any one could provide links or names of some items...
Much help needed thanks...
Dual Single DIN kit number
Metra = 95-3302 (ISO mount only)
6.) I have an 07+ and need a GM-LAN harness, which one do i get?
non pioneer = GMOS-LAN-03
pioneer = GMOS-LAN-04 *retains onstar*
7.) Is there another solution other then the pricy gm lan harnesses for 07+ vehicles?
Yes you can buy the regular harness that will plug in but you will loose your door chimes.
Metra = 70-2202
Metra = 70-2202
I also need help with this type of installation. I looked for those harnesses on eBay and it shows two different ones. It shows the GMOS-LAN-04 and there is this other one labeled GMOS-04. Could some verify if these are the same or does the "LAN" part make a difference?
agentirons
Oct 16, 2015 02:11 AM
shawnsseries
Sep 10, 2015 08:29 PM
