Radio won't turn on
Old Sep 28, 2010 | 03:54 PM
BULLETSSMOKE's Avatar
Radio won't turn on
So last night I popped a CD in the radio and it played, this morning when I went to take it out, it was stuck, great... Just now I took out the radio and disconnected it from the car and took off the faceplate so I could "manually" remove the CD. I removed it just fine. Put the radio back in the car and connected everything back up perfectly. It won't turn on, theres static"ish" noise but the faceplate doesn't show anything and the buttons do nothing. Help!
Old Sep 28, 2010 | 03:59 PM
gwatson650's Avatar
My cd player does the same thing. Usually if you just wait a few minutes then try to eject it again it will go. If not after you turn the car off it will eject.
Old Sep 28, 2010 | 04:01 PM
It was jammmmed in there. I had to push a little white thing down to remove the CD, the eject mechanism probably wasn't functioning right. BUT the main problem is that it won't TURN ON!!!! Grrrrrr
Old Sep 28, 2010 | 05:20 PM
gwatson650's Avatar
Hmmm. You try unhooking your ground from the battery? (negative wire)
Anythime something eletrical happens to my car, i just unplug that bitch for about 5mins.
Old Sep 28, 2010 | 07:10 PM
I unplugged positive for about 30 mins. Nothing.. What does ground have to do with anything?
Old Sep 28, 2010 | 07:18 PM
Pedobear's Avatar
check yo fuses son
Old Sep 28, 2010 | 08:22 PM
gwatson650's Avatar
Negative resets. Try that
Old Sep 29, 2010 | 10:48 AM
So I found out by driving at night, the radio background lights light up, it plays music, I can change volume and channels through the steering wheel controls. Just no faceplate anything.
06MetallicBalt
Jul 20, 2025 08:47 PM
Solaris99
28
Mar 15, 2017 01:22 PM
agentirons
Oct 16, 2015 02:11 AM
roth
Sep 26, 2015 12:16 PM
