Remote Start
Old Sep 14, 2008 | 05:19 PM
Broke EF's Avatar
Remote Start
OK I have a few questions about doing a remote start. First off If anybody has the wiring diagram for a 2007 Cobalt LS Couple that would be awsome. Second Im wondering if I need a Immobilizer Bypass? To clearify I have a 2007 Cobalt LS with 0 options, so I have the 4 speaker non poineer non on star stereo, that has been replaced using a GMOS-LAN-03 harness. Im trying to install a Hornet 569T remote start, Ive heard I need a DEI-555LW GM remote start interface mod passlock 1 & 2. Thanks for any and all help.
Sean
Old Sep 16, 2008 | 05:51 AM
Broke EF's Avatar
Nothin huh?
Sean
Old Sep 16, 2008 | 05:59 AM
Jn2's Avatar
Jn2
good luck man, i dont know of many that have remote starts, but try asking eperorj something like that, he might know, as he is the usual know how person when it comes to electrical
Old Sep 16, 2008 | 06:48 AM
SilvrLT's Avatar
PRINTABLE VERSION
CHEVROLET
MODEL YEAR(S)
COBALT 2006 -2008
KEY T-HARNESS IMMOBILIZER
N/A N/A GM'S PASSKEY 3 TRANSPONDER ANTI-THEFT SYSTEM, Requires BYPASS PKUGM2X OR XK06
PART COLOR LOCATION DIAGRAM
12 VOLT CONSTANT RED/BLACK (+) @ BCM, C3, Pin D1, See NOTE *1
STARTER YELLOW (NOT Required for REMOTE START) See NOTE *2 @ PCM, BLUE Plug, Pin 48, 46 or 56, See NOTE *2
STARTER 2 N/A
IGNITION 1 YELLOW (+) @ IGNITION HARNESS or BCM, C4, Pin D3, See NOTE *1
IGNITION 2 N/A
IGNITION 3 N/A
ACCESSORY/HEATER BLOWER 1 N/A @ IGNITION HARNESS or BCM, C4, Pin C8, See NOTE *1
ACCESSORY/HEATER BLOWER 2 N/A
KEYSENSE N/A
PARKING LIGHTS ( - ) BROWN/WHITE (-) @ HEADLIGHT SWITCH or BCM, C2, Pin 5, See NOTE *1
PARKING LIGHTS ( + ) BROWN (+) IN DRIVERS KICK PANEL or BCM, C2, Pin 5, See NOTE *1
POWER LOCK WHITE (1-Wire Door Lock System) See NOTE *3 IN DRIVERS KICK PANEL or BCM, C1, Pin 7, See NOTE *1 30303_COBALT_COBALT 06 1 WIRE JBS UNITS.pdf
POWER UNLOCK Same wire See DIAGRAMS 30303_COBALT_COBALT 06 1 WIRE ALERT SHELBY UNITS.pdf
LOCK MOTOR WIRE GRAY (+) IN DRIVERS KICK PANEL or BCM, C3, Pin A4, See NOTE *1
DOOR TRIGGER See NOTE *4 IN EACH KICK PANEL or BCM, C1, See NOTE *1 14301_COBALT_(-) NEGATIVE DOOR PIN ISOLATION CIRCUIT.pdf
DOMELIGHT SUPERVISION GRAY (-) @ BCM, C3, Pin A10, See NOTE *1
TRUNK RELEASE TAN (-) @ TRUNK RELEASE SWITCH or BCM, C2, Pin 10, See NOTE *1
SLIDING POWER DOOR N/A
HORN TAN (-) @ HORN SWITCH or BCM, C2, Pin 14, See NOTE *1
TACH ANY wire NOT PINK or PINK/BLACK @ ANY FUEL-INJECTOR
WAIT TO START LIGHT N/A
BRAKE LIGHT BLUE (+) @ SWITCH ABOVE BRAKE PEDAL
FACTORY ALARM DISARM DISARMS with FACTORY REWMOTE ONLY!!
ANTI-THEFT GM'S PASSLOCK 3 TRANSPONDER ANTI-THEFT SYSTEM @ IGNITION TUMBLER
NOTES
NOTE *1 the BCM is part of the FUSE/RELAY BOX on the front PASSENGER SIDE of the CENTER CONSOLE. The BCM has the following connectors: C1-72 Pin GRAY Plug, C2-72 Pin GRAY Plug, C3-41 Pin RED Plug, and C4-68 Pin LIGHT GRAY Plug, the C4 Plug, is located on the BACK of the BCM.
NOTE *2 the PCM (Powertrain Control Module) is located on the DRIVERS SIDE FENDER, in FRONT of the UNDER HOOD FUSE BOX. The YELLOW STARTER wire is NOT required for REMOTE STARTING. THIS VEHICLE REQUIRES A PKUGM2X OR XKO6 WITH PKG7 2.0 FIRMWARE BYPASS FOR REMOTE STARTING.
NOTE *3 This vehicle uses a 1-Wire Door Locking System that will require extra parts. The LOCK requires a Straight (-) Negative and the UNLOCK requires a (-) Negative thru a 1500 Ohm Resistor. Some units will also require (2) extra Relays Part #775 for this function, to connect See DIAGRAMS.
NOTE *4 The DRIVERS DOOR is a GRAY/BLACK (-) Pin 22, The PASSENGERS DOOR is a TAN/WHITE (-) Pin 19, The DRIVERS REAR DOOR is a LIGHT BLUE/BLACK (-) Pin 1 and The PASSENGER REAR DOOR is a LIGHT GREEN/BLACK (-) Pin 20, when connecting to an ALARM SYSTEM use all 4 wires and DIODE ISOLATE, to connect See DIAGRAM
LINK 1 LINK TEXT 1 LINK 2 LINK TEXT 2
EXTRA INFORMATION
Here is some wiring info I found in bulldog securitys website maby this wil help
Old Sep 16, 2008 | 06:28 PM
Broke EF's Avatar
That wiring should help alot, its the first one Ive seen for 07. It also calls out the immobilizer bypass that I enede up buying, so at least thats one more confimation for needing that.
Thanks,
Sean
Old Sep 16, 2008 | 07:02 PM
Doc's Avatar
Doc
shoot me your email address, I have a wiring schematic...its like 8mb, not sure if it covers 07's though
Old Sep 16, 2008 | 09:56 PM
EmperorJJ1's Avatar
Thanks,
Sean
yes u will need either the passlock bypass unit or the key in box unit
Old Sep 18, 2008 | 01:45 PM
Broke EF's Avatar
Ok I just got this response from another forum
Below is about an 08 cobalt. I have no idea if it is the same as the 07. If it is the same, please read below.
Yes it is on, I didn't want to be the one to burst your bubble. But since nobody else wants to burst it for you here we go. The vehicle you purchased is a computer controlled car, known as a DataBus system. Years from now I think it may be a great idea. Today, it's only purpose is to make installers pull their hair out. I would reccomend using an Audiovox Prestige alarm system and one of their Flash Logic pieces. Even using the correct module there will still be issues. We worked on a car for 2 days. When you put the car in reverse, you had a 50 50 shot at having power steering. There were many more issues but that is the one they had the most trouble with. Turns out there are a ton of updates that the dealership needed to do to the car's computer. They were not real willing to help. It was a dealership job. The salesman misrepresented the car and told the customer it had remote start. After the 2 days of work, we then found out that for the dealership to install the factory remote start, the cost for them would have been minimal. 1 new computer module and 2 remotes. You may want to look into that option. I really suggest you shop around and find a shop that has installed an alarm in one of these vehicles before. With the flash logic piece and the alarms that they were designed to mate with, there are a lot fewer wire connections to be made, but there are the programming issues. Good luck in whatever you do, and remember to disconnect the negative terminal of the battery before doing any work on the vehicle.
Anybody have any insight into this? For the record I already have a Hornet 569T remote start and a PKUGM2X bypass unit. Any help/info on this is GREATLY apreciated.
Thank you,
Sean
Old Sep 18, 2008 | 05:37 PM
Spun's Avatar
I have one in stalled in mine, its not impossible.
Its hard and he's right the installers call my car "The Bitch"
Listen, I don't know too much about alarms but I tell you whatt i do know
1 getting your remote start to learn the tach is going to be hard, your going to have to force it.
2 bypass all the crap with the ignition and the tach go strait to the source
3 the RAP feature causes problems with reservation mode,
4 the BCM tends to go into sleep mode every once and a while, we can't seem to find a pattern, but it will cause the doors not to unlock or alarm to stay armed (the bcm needs to send out 3 pulses one for the alarm and one for each door, when in sleep mode the first pulse goes to waking up the system)
5) Get a COMPUSTAR, you have a high tech car so get a high tech alarm that can interact with it. You would try and hook a DVD player up to a 1970's TV without some kind of adapter in there, compustar has the adapters or Modules and better yet there real easy to program,
I have the Compustar P2W900FMR, it will cost ya, but its worth it
Old Sep 18, 2008 | 08:59 PM
Cefaln452's Avatar
I have that alarm tooo, the pro edition,,, so how do you like it? i havent installed mine yet.
Old Sep 24, 2008 | 09:37 PM
Broke EF's Avatar
Bump for anymore help.
Sean
Old Sep 24, 2008 | 10:02 PM
glen229's Avatar
im doing my auto start next month.. with the clutch bypass.. oh its gonna be a joy!!!!!!!!!!!
Old Sep 24, 2008 | 10:16 PM
jschatte's Avatar
Thats what i got, i had the dealer install it... my wallet was considerably lighter after that lol
Old Sep 25, 2008 | 12:01 AM
EmperorJJ1's Avatar
how much did u pay? jschatte?
Old Sep 25, 2008 | 06:25 PM
Broke EF's Avatar
Well Im doing mine saturday, I will share any knowledge I get, and I may take pics of it all. Well have to see how frustrating it is.
Sean
Old Sep 25, 2008 | 08:06 PM
07blackss86's Avatar
1. The car not learning tach is absolutely incorrect. I ran mine on voltage first but it started up like crap from time to time so I made the switch to tach, no problems at all.
2. RAP has not caused any issue in my car and I'm not sure what that would have to do with your system.
3. The BCM going to sleep? Really? Are the installers telling you that because if they are they need to study up. That sounds like the GEM module used in Ford's and I highly doubt they are in our cars. I have had no problems with my doors unlocking or locking or the alarm not staying armed.
4. Any system will work in any car, I have a Viper on my car with an XK06 bypass module and the install was cake. I have also done several Vipers on other Cobalts with no problems.
I'm not trying to bust your *****, just trying to clear up some things, especially if it is other installers telling you this. I do this for a living so I try to stay on top of my game and follow up on things. Sorry if it seems like I'm trying to be a dick. As far as doing alarms/remote starts on your own, I highly advise against it. Way too many electronics that have the potential to be damaged if you aren't sure what you are doing, I have seen it time and time again. Doing a radio is a lot different and a lot easier. I give anyone who tries it on their own a lot of credit for trying, but be careful because if you cross just one wire you could be in big big trouble. If anyone has questions feel free to pm me.
Old Sep 27, 2008 | 12:58 AM
Broke EF's Avatar
Ok so I got it in, and working with only a couple small issues. First off when I turn off the car with the key OR with the remote start the starter tries to restart, Its not a full on crank, more like not enough power half assed attempet. Next is its flashing the headlights and not the parking lights. According to two different wiring diagrams I have the right wire for it, just isnt right. Im mostly concerned with the starter thing though. FYI it is a manual and for testing the clutch switch is tapped down to trick it (this is only to see if it would start, and isnt going to stay like that) also the brake "kill" wire isnt hooked up. ANY information is GREATLY apprciated.
Thanks
Sean
Old Sep 27, 2008 | 10:42 PM
glen229's Avatar
bump id like to know these answers
Old Sep 27, 2008 | 10:50 PM
BIG-DAVE's Avatar
i have it on mine but i paid to have it installed
Old Sep 28, 2008 | 09:41 AM
glen229's Avatar
how much... manual or automatic?
Old Mar 26, 2009 | 10:51 PM
pccobra's Avatar
Need help...anyone know where I can find the 12 volt brake switch connector wire on a 2009 Cobalt? The wiring info I have suggest that it would be just above the brake pedal which is where it was on my old 2005 Cavalier. On the Cobalt there are 3 wires...yellow, brown, white.....should be Lt. Blue.
Autopage RS-660 with CAN SL-2 databus bypass tested and working fine.
Old Mar 26, 2009 | 10:53 PM
D4u2s0t's Avatar
you guys with the manuals, you're trusting just your weak ass ebrak to hold the car from rolling? pretty ballsy
i'll take a look in my book and see if it has wiring diagrams. pretty sure it does.
Old Mar 27, 2009 | 12:39 AM
Cefaln452's Avatar
Light blue is e brake my fellow... Pull off the plastic shroud and there she is
Old Mar 27, 2009 | 01:08 AM
koch1ar's Avatar
sub'd
are you guys w/ manuels getting installed at shops? no one around here will even look at my car. lol
and yes i know about liability
Old Mar 27, 2009 | 05:16 AM
pccobra's Avatar
Brake switch location
Thanks for the info....however I'm looking for the LT.BLUE wire that gets 12 volt when the brake pedal is pressed so I can disable the remote starter after inserting the key to take full control...
My apologies everyone my car is an Automatic 2009 Cobalt, sorry I forgot to mention that.
pccobra
