remote wire?
Old Jul 27, 2008 | 02:18 AM
silver187666's Avatar
remote wire?
i installed a new HU a month ago, im about to hook my 2 12", the amp needs a remote wire, but the gmlan 03 uses it to, can i just connect the remote wire from the hu to the lan and the amp?
and can i bridge my audio blinker in to the speakers just like the warning sounds do?
Old Jul 27, 2008 | 02:23 AM
KillerBee's Avatar
Yeah but is there not a blue remote wire on the new HU wiring harness but i am sure you can use the same one as to the one for the HU
Old Jul 27, 2008 | 02:27 AM
there is one ont he head unit, but its connected in to the lan, i was wondering if its ok to connect 2 in to one?
Old Jul 27, 2008 | 02:30 AM
EmperorJJ1's Avatar
^^^^^^yes
Old Jul 27, 2008 | 02:39 AM
can i connect my turn signals into the door chime or radio speakers?
Old Jul 27, 2008 | 03:30 AM
Spun's Avatar
If you have the GMOS LAN 03 that your turn sign. and chimes should already be running through the drivers side door speakers the remote wire has nothing to do with this at all.
This is as easy as I can explain this, Run the remote wire (might as well do your RCA's at the same time) down the passenger side of the car and up under your dash. Pull your HU out and find where the HU's remote and the Lan's remote are connected together, pull them apart.now take the wire you have running to the amp and twist all 3 together, throw a dab of soder on there (optional) and then cover the open wires with some heatshrink or electrical tape, put the HU back in place, connect the wires to the amp and happy listening.
Note: make sure you disconnect the battery before you start doing anything or you'll blow the radio fuse when you take the HU out, or when you put it back in
Old Jul 28, 2008 | 03:50 AM
the lan 03 didnt retain the tunr signal sound
Old Jul 28, 2008 | 04:09 AM
Spun's Avatar
You need to add a relay, the instructions on how to do it are in the manual that came with the Lan 03.
When the factory radio is removed the audible turn signal indicator is lost.
If that turn signal “clicking” is desired follow these steps:
1. Using a SPDT relay (Metra part # E-123), connect pin #85 to the
Black/White wire in the 12 pin harness.
2. Connect pin #86 to the 12 volt constant wire on the 12 pin harness.
3 . Be sure to cover the other leads of the relay by either using female spade
connectors or using tape to cover the leads.
Now when the turn signal is on, the relay will make the audible “clicking” noise
Thats from the install manual of the GMOS LAN 03
Old Aug 31, 2008 | 01:12 AM
tone8275's Avatar
Can someone give direction as to what wire I can connect a remote wire to?
Any help is greatly appreciated.
Old Aug 31, 2008 | 02:32 AM
EmperorJJ1's Avatar
hit up the faq... you need to run a fuse tap to the sunroof or wiper fuses with a stock deck. aftermarket deck run to the remote wire (blue/white) or the power ant wire (blue) for the lower end units
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
dennis69
Oct 20, 2015 07:39 AM
ernnyyes
Oct 2, 2015 05:16 PM
c_m_shooter
Sep 27, 2015 04:40 PM
jmelton327
Sep 26, 2015 10:04 PM
