reverse lights as brake lights
Old Jan 13, 2009 | 06:10 PM
Stubri51's Avatar
Arrow reverse lights as brake lights
I know people have made there reverse lights into brake lights by adding LED strips. Is it possible to make them be running lights, brake lights and turn signals all on one set of lights. I have thought about it and the only way I can see is to use two sets of lights and wire one up as the running lights and the other as the brake/turn lights. Thanks for the help
Old Jan 13, 2009 | 10:19 PM
Spun's Avatar
IPCW
All 4 work as running lights, turn signals, and brake lights
http://www.inprocarwear.com/
Old Jan 13, 2009 | 10:23 PM
yellowltcoupe22's Avatar
you dont have to use two sets. you just need adjustable resistors and some diodes to use a single strip of leds for all of it. look at the how-to's. there is a guy that explains how to do it around post 60 i think in one of the how-to's. i've explained it to someone before and they did it as well
Old Jan 16, 2009 | 08:04 PM
NCC-2000's Avatar
Do what I did.
Only difference is mine won't act as turn signals. I didn't want them to. Less wire to run up the trunk lid too. But to do it, you just have to run a wire from the brake lights on both sides up to the trunk lid, where as I only tapped into the third brake light.
http://www.youtube.com/watch?v=L8DE6WtUm-I
Old Jan 22, 2009 | 12:00 AM
ssyeller's Avatar
Another option
Running back up lights red outside ring of leds as running lights with another set of amber leds in the middle for turn signals Put my back up lights as led strips (10mm white 6 in. both sides) behind the grids by exhaust. Also added Red strips same location as red brake lights behind grids.
Hooking up led-spider.com sequencer for sequencial lighting (old thunderbird style and new mustang style) Using led-spider requires no diodes resistors all done on the board with internal clock for blinking speed. Also will control incandescent lighting.
Pictures to be available in about a week or so. Hooking up the front and back at this time.
Will have sequencing leds inside the rearview mirrors as well as the white leds in my halos will sequence.
Putting superbright yellow leds in my halos instead of white also.
Old Oct 10, 2011 | 11:30 PM
MastaShaKe_88's Avatar
subd
Old Oct 11, 2011 | 02:59 AM
dtowngreg's Avatar
how much do u guys think this would cost to get done at a shop?
Old Oct 11, 2011 | 11:26 PM
ssyeller's Avatar
convert backup lights to running lights.
Easy go buy 3 in led lights Trucklite, maxximum, and others and put behind the backup light lens and attach the wires from the other brake lights and you are done. Way less than 50.00
I have switched my regular lights to led with 30leds for under 50.00 for the pair. Took me 3hrs to modify and install.
Old Oct 12, 2011 | 03:29 PM
dtowngreg's Avatar
So any idea of how much this would cost if I got it done at a shop
Old Oct 12, 2011 | 03:53 PM
did i have to rip apart the casing to do this?
and op, no idea how much it would cost for a shop to do, def. wouldn't be cheap though
Old Oct 13, 2011 | 12:48 AM
ssyeller's Avatar
Ok here you go. How to have all features on the cheap
You can do your self easy.
First take out the brake lights You will notice on the back a ridge on the back side that just happens to be 4in round and is parrallel to the back of the car so no tweeking angle
JUST CUT ALONG THAT RIDGE AND ATTACH 4IN ROUND STOP TURN LED LIGHT TO THE BACK AND HOOK UP TO CAR WIRING AND YOU ARE DONE. SAME WITH BACK UP LIGHT.
Need more info and pictures of how I did this 503 806 7117
No custom wiring no nothing but 3 blue butt spices.
I could do just like mine for 25.00 plus parts. insurancesigns@yahoo.com
Old Oct 13, 2011 | 02:28 AM
dtowngreg's Avatar
So under a 100 should be fair? Cause I don't trust myself with that. If probably mess something up somehow lol
Old Oct 13, 2011 | 04:10 AM
Berto09ss's Avatar
hmmm i might try this but any tips or tools i might need?
Old Oct 13, 2011 | 11:05 AM
i want skyline tails! group buy, group buy!!
Old Oct 13, 2011 | 11:24 AM
1LowLS's Avatar
All using regular bulbs although I didnt have reverse lights at all.basically I put red bulbs in the reverse lights andwired the pigtails into the brake light circuit,then added a red 194 socket in each reverse light and wired them to the running light circuit
my balt 007 - YouTube
Old Oct 13, 2011 | 11:28 AM
nice howd u manage? just use a fitting bulb and tap into the drls?
1LowLS's Avatar
above post edited
Old Oct 13, 2011 | 11:29 AM
ssyeller's Avatar
Pull the tail lights out so you know
What is up. Take 2 wing nuts off pull the tail light out and call me. I will tell you how to do.
You will need a saw of some kind band saw prefered but hack saw will work because you need to cut through the plastic. A dremmel tool to grind down the rest since you can't cut all the way through because some is below the lip of the light. This will become obvious when you take it out.
I can send you a picture of mine. I just used gorilla tape to hold the replacement lights in place.
Walla. Go to trucklite.com look and any 4in round stop turn led light. The more LED's the more money.
I went to 26 to 30 LEDs but you can go up to 50 some. The more LED's the more upscale looking.
Send me your email address and I will send pictures. Not good at putting up pictures on here. You can do that if you like.
Old Oct 13, 2011 | 01:41 PM
dtowngreg's Avatar
Did u also paint the clear part of the light red?
Old Oct 13, 2011 | 03:07 PM
ssyeller's Avatar
back up lights need not paint or cover clear part
Led light can be clear plastic or red plastic. Thus the lights them selves can be amber or red. If red they just show up as all red through clear and red part. Just using 3in Led stop turn trucklite light
Old Oct 13, 2011 | 03:31 PM
dtowngreg's Avatar
i want skyline tails! Group buy, group buy!!
+1
Old Oct 13, 2011 | 04:04 PM
dtowngreg's Avatar
Oh ok cause it looked like the whole lense was red. So if u turn the car off will it still be clear or red
Old Oct 13, 2011 | 09:08 PM
1LowLS's Avatar
no the lens is clear and im not using led's.the bulbs are red
Old Oct 13, 2011 | 09:46 PM
ssyeller's Avatar
exactly if LED lights red still clear
You can get transparent vinyl that is red and cover the clear if you like the all red look. Looks better just the way it is and let the lights just be red.
Old Oct 13, 2011 | 09:58 PM
dtowngreg's Avatar
Thanks man. I'm just gonna get the inners done with reg bulbs. Cheaper too.what size bulb did u use
