Safe Voltage Levels
Old Jun 25, 2007 | 04:00 PM
Xavipheus's Avatar
Safe Voltage Levels
So my headunit and and AMP are reporting a 15v voltage when my car is on, is this safe??? Im assuming my alternator is having no problem keeping up with my system I suppose
Old Jun 25, 2007 | 04:05 PM
Bandit2941's Avatar
That's strange. What does it drop to when it's playing? I wouldn't expect to see anything more than 14.4 or 14.5V or so. Factory alternator?
Old Jun 25, 2007 | 11:02 PM
Xavipheus's Avatar
Nope hardly drops at all only time i cant even get the voltage to drop is if i use the windows (those motors take alot of power) and even then it hovers above 13-14...and yes factory alternator
Old Jun 26, 2007 | 03:30 AM
EmperorJJ1's Avatar
hmm throw a volt meter on your alt itself... that shouldnt be that high but i wouldnt worry to bad (you will probably need a new alt sometime and hopefully by then some aftermarket place will make them)
Old Jun 30, 2007 | 10:31 PM
Bumpin Balt's Avatar
Most after market electronics can handle up to 16V. The more voltage your system gets, the higher your output will be (more watts). That's a good thing!
Old Jul 1, 2007 | 06:33 AM
EmperorJJ1's Avatar
extra voltage is good for the audio stuff but bad for your car... bump your voltage up higher and see the computer fry ect ect
Meadowvalien
Aug 17, 2017 06:32 PM
toysareforboys
Nov 17, 2015 05:22 AM
patooyee
Oct 15, 2015 05:11 PM
Extremespeed
Sep 29, 2015 04:34 AM
Rduncanss06
Sep 27, 2015 11:17 PM
