Sedan Owners
Old May 18, 2009 | 12:42 PM
cobalt123's Avatar
Sedan Owners
Has anyone installed any speakers in their rear passenger and drivers side doors????
I was thinking of doing this is this redundant or what??? maybe matching 6x5s
Old May 18, 2009 | 04:38 PM
ipwncivics's Avatar
free bump
Old May 18, 2009 | 05:45 PM
cobalt123's Avatar
Old May 18, 2009 | 09:52 PM
Ishbar's Avatar
I dont understand, is there even wiring for that?
I thought there was only two in the front and two in the rear?
Old May 19, 2009 | 07:38 AM
cobalt123's Avatar
thats true, 6x5s in front 6x9 in rear deck, and yeah i know i got some wiring to do just wondering if anyone has done it and maybe had some advice before i start
Old Jun 28, 2009 | 08:39 PM
cobalt123's Avatar
bump for suggestions
Old Jun 28, 2009 | 09:04 PM
06'L61'Balt's Avatar
i just rewired my speakers into my aftermarket headunit but i think there are wiring harnesses to convert the factory wiring and if you put a new stereo in then you are going to have to tap into your fuse box and run a wire the remote wire on the remote wire on the stereo, its pretty easy, just takes patience.
Old Jun 28, 2009 | 09:08 PM
cobalt123's Avatar
i figured that it would work, it doesnt seem like an impossible concept, i figure i have 4 doors might as well use them for something, haha consider it surround sound
Old Jun 29, 2009 | 02:00 PM
Nighthawk243's Avatar
You could probably do it, but you would need to run your own wiring, cut your own holes in the door panels, and do all the measurements to make sure that you're not going to have fitment or operational issues (The window's ability to roll down is a HUGE one.)
There should be a rubber boot that goes from the door jam into the door (For power locks/windows) that you can run your wires through. You will need to find a way to amp the speakers or run them to the (tap them into the front or rear) without screwing up the impedance of the system.
Old Dec 2, 2009 | 07:53 PM
ipwncivics's Avatar
i did it cut out the bottom slot or whatever for randon stuff and used the space, kinda sticks out a tad. 0.05 in but it works
06MetallicBalt
Jul 20, 2025 08:47 PM
Supercharged06SS
Dec 11, 2022 04:47 PM
Oct 20, 2015 09:56 PM
maliki778
Oct 1, 2015 07:39 PM
Dylan Johnson
Sep 30, 2015 08:57 AM
