Seperating Turn signal...
Old Dec 15, 2009 | 06:12 PM
MBMCustoms's Avatar
I am doing a project with my tail lights. I have it all put together... but, I need to know how to seperate the wiring to where i have a seperate brake light from the signal light. anyone know how to do this?
Old Dec 15, 2009 | 06:39 PM
Maven's Avatar
You would have to run all new wires for the rear lights. Youd have to make the brake lights run off the CHMSL, and youd have to make the turn signals runn off the front turn signals.
Old Dec 15, 2009 | 06:43 PM
Gestapo007's Avatar
disconnect the signal or brake wire, whatever one you want from the harness, and run it to whatever you want to illuminate for braking/turning. remove your brake light harness, get a test light, turn your blinker on, see what one flashes
Old Dec 15, 2009 | 06:52 PM
Maven's Avatar
The signal wire and the brake wire are the same wire. The body control module directly powers the rear lights, if it wants it to blink, it blinks it, if it wants it to be a brake light it makes it a brake light.
My way is pretty much the only solution I am aware of, its not "hard" its just a lot of wire to run.
Old Dec 15, 2009 | 06:58 PM
Gestapo007's Avatar
^ahh that makes sense now that i think about how a turn signal works lol
Old Dec 16, 2009 | 03:09 AM
EmperorJJ1's Avatar
damn i thought there were 2 wires... i havent looked thou... what are u trying to do might i ask
You can get "brake only" from the 3rd brake light... mine was green if i remember correctly (which i might not) I ran a wire into the car incase i ever do something crazy with my lights i don't have to worry about it
Old Dec 17, 2009 | 01:03 AM
MBMCustoms's Avatar
i am retrofitting some lights from another car. thanks for all the info. i will get it done soon and post pics and vid. thanks guys!!
Old Dec 17, 2009 | 02:24 AM
EmperorJJ1's Avatar
if ur doing passat tail lights then i hate you unless you give me a pair too. If you doing a diff car then disregard
Old Dec 17, 2009 | 11:54 AM
Maven's Avatar
"3rd brake" = "CHMSL"
Old Dec 18, 2009 | 12:48 PM
MBMCustoms's Avatar
^ what?
Old Dec 18, 2009 | 12:54 PM
JL-KA's Avatar
http://www.youtube.com/watch?v=Mtjovjqt9r4
Old Dec 18, 2009 | 06:01 PM
08G5GT2.4L's Avatar
Originally Posted by MBMCustoms
^ what?
CHMSL = Centre High Mount Stop Lamp i.e. 3rd brake light.
Old Dec 23, 2009 | 01:36 AM
727's Avatar
727
You can place wires from BCM module to rear-side ... using Front-Turn pins ...
If you want - i can post image about it ... because I maked it in my Balt for additional rear-turn signals.
06MetallicBalt
Jul 20, 2025 08:47 PM
Solaris99
28
Mar 15, 2017 01:22 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
roth
Sep 26, 2015 12:16 PM
