Setting the alarm
Old May 29, 2012 | 09:57 PM
cobalt_sport08's Avatar
Question Setting the alarm
Ok so right now my remote isn't working and well I can't set the alarm on my car right?? My friend was telling me that if you hit the lock button twice on the door it sets the alarm, well i tried it and it didn't work for me.. is there any other way to set the alarm?
Old May 29, 2012 | 10:02 PM
BPacak's Avatar
Vtec Rep
pretty sure if you do set it every time you open the door the alarm will go off until you start the car.
Old May 29, 2012 | 10:14 PM
thats what im asking how do you set it? if i lock my car with just the inside lock(b/c remote is not working) and my window is down and you pull the lock and open the door the alarm will not go off.
Old May 29, 2012 | 10:23 PM
brycerice13's Avatar
yeah hit the lock button twice on the door will arm the alarm. It won't beep the horn like when you do it with the remote it only dings the dash alarm to make sure you have the keys.
Old May 29, 2012 | 10:24 PM
ok ill have to give it another try again tomorrow
Old May 30, 2012 | 05:26 PM
EmperorJJ1's Avatar
it should set even if u press it once really. pressing twice just gives u the confirmation ding
Old May 30, 2012 | 08:07 PM
yeahh.. no alarm went off when i locked it with the door lock >:l
Old May 30, 2012 | 08:31 PM
tomj77's Avatar
if ur remote isnt working, take it apart, the contacts for the thing that holds the battery and presses on negative may be pulled out, mine did, gotta solder them back in
Old May 30, 2012 | 08:44 PM
Edubs's Avatar
How long did you wait to pull up on the lock and open the door? You have to let the alarm set before you open it. If you just lock it with the door luck, shut it and then pull up on the lock it won't go off. You have to wait a few minutes for the alarm to set...
Old May 30, 2012 | 08:45 PM
Edubs's Avatar
If the battery hold down is still together, the contacts themselves on the circuit board may be worn out. They sell contact patch kits that you add into the remote that restores the connection...
Old May 30, 2012 | 09:27 PM
already did that and got anew battery
I got home from work got my stuff out hit the button twice then got a shower(so about 30mins later) went back out pulled up on the lock and opened the door nothing happened. the alarm light doesn't even flash
thats fine to because im buying a new remote when i finally get paid
Old May 30, 2012 | 09:45 PM
BlueStang's Avatar
You need a working remote as that is the only way to arm the factory alarm on it.
Old May 30, 2012 | 11:01 PM
EmperorJJ1's Avatar
no its not i have both my stock remotes that are fucked and i lock my car with the lock button on the door (both driver and pass doesnt make a difference) every day and when i open it again with the key it activates the alarm every time
have u tried opening the passenger door? and not that it makes a difference or shouldnt but roll up the windows and use the key
Old May 30, 2012 | 11:38 PM
maybe its just my car idk and no i haven't yet its not that big of a deal i was just wondering why it doesn't go off.. and i just crack my windows and sunroof when im at work
OrangeCoba
Oct 1, 2015 10:00 PM
DANRICKARD
Oct 1, 2015 12:08 AM
Tupp
Sep 30, 2015 08:18 PM
Sep 27, 2015 08:53 PM
