So the door panels are off....
Old Oct 22, 2005 | 08:55 PM
ComputersAre8ad's Avatar
Okay, so I'm putting in new speakers for hte first time, well... I've got the panels off, factory speakers out, and now I have a new problem... fitting the new speakers in, does anyone have any idea if I was supposed to have some sort of adapter for this and I'm just that much of a noob that all the other car audio noobs knew about it and I didn't?
J
Old Oct 22, 2005 | 11:41 PM
Cobalt30's Avatar
i think i know what your talking about even tho i havnt seen mine. from the wires to your spearker wires has a speical connection clip thingy. What you can do is either cut connection off of both of them and just connect red to red and black to black. or you cut the connection off your speaker side and connect that to your new speakers and connect that to the other connection.
can somebody back me up here cuz im not 100% sure .
ryan
Old Oct 23, 2005 | 01:26 AM
Clmbngfrk18's Avatar
no what he means is the actual speaker doesnt fit right i havent looked at mine yet but you probally need an adapter lots of new cars do are you using a 6.5 might be able to bullshit it for now and get the parts you need
Old Oct 23, 2005 | 01:48 AM
05stockbalt's Avatar
J
not really sure what you are saying so i will just give u a play by play the factory size for a speaker is a 5 1/4 inch speaker you can fit 6 1/2 in speakers in you will only be able to get 2 screws in though as far as the wiring goes don't cut the factory harnesses they sell speaker harnesses for that particular reason unless you have acess to a website that can tell you the polarity of the wires you are using you will have a 50/50 shot of guessing the harness elimnates the possibility of you hooking it up wrong they are like 6 or 7 bucks at like best buy or circuit city hope this helps pm me if you have any questions
Old Oct 23, 2005 | 02:29 AM
i though the stock speaker were 6.5 inthe front and 6x9's in the rear
Old Oct 23, 2005 | 12:01 PM
mcphatty's Avatar
okay, this is really easy guys
when i installed my door speakers, i clipped the connectors off the stock harness.. leave enough room on the clip end of the wire so you can reconnect them at a later date if need be. on the left door, the wires are light green and dark green. connect the light green wire to the red connector on the speaker, and the dark green to the black connector on the speaker. you can double check the polarities by looking up by the tweeter on the door, and you'll see the green wires plugging into the red and black wires for the tweeter.. on the right door, the process is the same, but the wires are grey and dark tan. grey goes to red, dark tan goes to black.
simple as that, and my rockfords sound amazing
Old Oct 24, 2005 | 05:16 PM
VictoryIsMine's Avatar
McPhatty's right. The wiring is very easy, you just have to cut it. The stock speakers are 6 1/2" and not 5 1/4". I was able to fit my 6 3/4" MB Quarts in the door with no problems at all, and I was able to use the factory holes for the 4 screws.
Old Oct 24, 2005 | 06:27 PM
T Dawg's Avatar
sounds to me maybe the base speakers are 5 1/4 and the pioneer set is 6 1/2?
Old Oct 24, 2005 | 06:45 PM
See, it's funny cause when I took out my speakers there wasn't four holes to mount the speakers on.... hense where my problem was.... the speaker itself was a weird shape and everything... it was like a speaker + fitting adapter all in one... it was retarted. My door speakers were also 4 ohms, which I know people have been saying theirs were 2 as were their back speakers. I really must have gotten the most retarted Cobalt on the market cause it doesn't match up with anything anyone else seems to have gotten thus far. Anyways, speakers are mounted, I had to tap mounting holes into the steel of my door, and it's there for now and later on I'll go back and get it professionally done... thanks for the input.
J
Old Oct 24, 2005 | 06:54 PM
mcphatty's Avatar
mind if i see some pics? im kinda curious as to what the hell happened on your end
Old Oct 25, 2005 | 04:19 AM
I'll see what I can do, tonight I had a few too many to drink, and I'm not sure where I have my camera....Wednesday is my day off, expect them then.
J
Old Oct 26, 2005 | 05:30 PM
CobaltDude81's Avatar
my base model coupe had 6.5s in the front.... i held them up to eachother and they were the same i drilled holes in the metal to mount them. why mount smaller speakers to have it held on by 2 screws and rattle to hell?
Old Oct 29, 2005 | 08:54 PM
Mine had 5.25, I held 'em up to each other too.... and like I said I've got an off the wall car aprently, with my 8ohms back speakers and 4 ohm door speakers, but atleast I'm not the only one who had to drill holes.
J, still meaning to get inside my door for pictures (I plan on replacing the speakers again with components in a couple of months after I get some wheels and tires, and maybe the short throw & Intake.)
Old Nov 19, 2005 | 12:55 PM
qcpursuit's Avatar
Hey you just have to cut a little adapter in 1/2 MDF,drill the diameter of your new speaker in it and screw the adapter in the factory holes.Clean cut no metal vibration no rattles and just be sure to put some dynamat like(or anything like this) between the adapter and the door.
This a great custom job very fun to make
brickloaf
Show & Shine
56
Jun 18, 2019 12:51 PM
Extreme Dimensions
Sep 24, 2015 05:24 PM
dieGone
Sep 23, 2015 10:20 AM
The Rookie24
Sep 14, 2015 07:03 PM
chris88z24
Sep 8, 2015 01:55 PM
