Speaker static & engine noises
Old Jul 19, 2011 | 09:57 PM
strykr's Avatar
So I dont understand what happened, but just recently I have been having a problem with my driver side door tweeter and passenger side rear deck speaker.
The tweeter in the door makes engine sounds and static sounds, as the rpm's rise the engine sounds get more high pitch. Almost a slight whistle that sounds like a supercharger coming from my door. It only happens when i hit a good bump, and then i found out from palming the passenger side center console next to the radio that it goes away till another bump.
The rear speaker only makes the static sound, and doesnt go away even with the "palm method" lol
What could it be causing this? I originally thought i was close to killing the speakers before i stumbled across palming the radio console lol Now im thinking loose wire, but I just want to see what others think before i start ripping the stereo back out.
Old Jul 20, 2011 | 05:22 AM
EmperorJJ1's Avatar
do u have any aftermarket parts?
Old Jul 20, 2011 | 05:52 AM
SatanzSS/SC's Avatar
do you have an aftermarket headunit?
Old Jul 20, 2011 | 06:33 PM
strykr's Avatar
Hey I have a pioneer deck unit, with the Pac module and xm adaptor hooked up. Everything was plug n play (no wire cutting). Other then the deck, the pac module and xm adaptor everything else is still stock.
Old Jul 20, 2011 | 08:54 PM
EmperorJJ1's Avatar
does the pac module have rcas or speaker wire? if its rcas google pioneer pico fuse if its speaker wire then double check the ground and all connections. possibly ground the chassis of the radio to the chassis of the car
Old Jul 21, 2011 | 02:15 PM
strykr's Avatar
Speaker wires
Old Jul 21, 2011 | 03:28 PM
EmperorJJ1's Avatar
if thats the case id check all connecions like i said make sure something isnt loose and if not do the direct chassis ground to the deck. if that doesn't work then its the pac module and you need to swap that out
Old Jul 23, 2011 | 04:53 PM
user 72239's Avatar
Mine is doing this too, but only out of my passenger side Tweeter After a bump. Im gonna check the Headunit since i have an aftermarket one.
biniecki
Oct 25, 2015 02:23 PM
jimbofug007
Oct 2, 2015 12:06 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
