The start of my GF's 06 install
Old Sep 28, 2009 | 07:24 AM
Pontiac.G5's Avatar
so i ordered parts for the install i am doing in my GF's 06 cobalt
paid $75.90 for install parts and $127.99 for the radio she wants.
ordered parts:
Steering Wheel Control Interface
PAC SWI-PS - $43.99
http://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEWNX:IT
Antenna Adapter
MBA1B - $4.98
Wireing Harness
70-2103 - $10.98
Dask Kit
99-3302 - $15.95
http://cgi.ebay.com/ws/eBayISAPI.dll...d=469087080016
Radio
CDX-GT630UI - $127.99
http://www.dealercostcaraudio.com/sonycdx-gt630ui.aspx
So is there anything i should keep an eye out for when doing the install... i know i will have to run a acc wire to my fuse box (to an 15 amp fuse? usually i put remote wires (for amps) on the sunroof fuses). but anything else or clarification on the acc wire would be great too.
Will update with pics on finished product.
Old Sep 28, 2009 | 12:25 PM
EmperorJJ1's Avatar
just remember the swi needs an acc as well and it helps if the data wire is soldered
Old Sep 28, 2009 | 02:56 PM
Pontiac.G5's Avatar
which wire data n i'll prolly solder all the wires except the ones in the car...
n the acc does go to a 15 amp fuse right? the sunroof should be 15 if i'm not mistakin
Old Sep 29, 2009 | 02:02 AM
EmperorJJ1's Avatar
when u get the swi ps it will tell you to connect one wire from it to one in the harness thats the data wire. then connect a wire in the harness to ACC... that doesnt matter if its soldered or not (i used a t-tap)
lowest is 10a so wiper or sunroof fuse
Old Sep 29, 2009 | 03:13 PM
Pontiac.G5's Avatar
so i need to hook the acc wire to a 10amp fuse
Old Sep 30, 2009 | 01:43 AM
EmperorJJ1's Avatar
no you can hook it up to the sunroof 15a fuse if it works... the lowest amprage fuse you can use is 10a anything higher is fine
Old Sep 30, 2009 | 02:43 PM
Pontiac.G5's Avatar
cool will keep that in mind...
got the dash kit in the mail today.
Old Oct 1, 2009 | 11:24 PM
Pontiac.G5's Avatar
antenna adapter here
harness here
blue wire is for Antenna correct? so i don have to hook that up lol
Old Oct 2, 2009 | 02:56 AM
EmperorJJ1's Avatar
pioneer system? hook it up....
basic system? cap it off
Old Oct 2, 2009 | 06:38 AM
Pontiac.G5's Avatar
basic...
Old Oct 12, 2009 | 04:23 PM
Pontiac.G5's Avatar
oka doing the install and ran into a problem tryin to program the steering whell controls...
says somethin about hooking wire (white/black) at A10 to remote 12+ is this correct? i don wanna **** it up by doin this if it not supposed to be
Old Oct 12, 2009 | 04:27 PM
EmperorJJ1's Avatar
sounds about right... i remember having to hook up a wire to ACC. white/black sounds familiar
double check if its ACC or constant
Old Oct 13, 2009 | 04:20 PM
Pontiac.G5's Avatar
it is ACC and it is the white/black at A10... the reason it wasn't working was i was programming it wrong... you push the button to program then start while the light still lit... i thought (directions said) to start after the light went out. but its all working properly... except the preset button... it labeled "1 - 6" i set it as preset + but its seek >> lol so i (well she) has two seek >> buttons... but it works great. she couldn't be happier with the radio she chose
Solaris99
28
Mar 15, 2017 01:22 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
DANRICKARD
Oct 1, 2015 12:08 AM
Adiaz1ss
Sep 26, 2015 11:51 PM
