stock amp ?
Old Dec 25, 2006 | 11:48 AM
Crazypolak00's Avatar
stock amp ?
i tried a search but really couldnt find what i was looking for..does anyone know where the stock amp is located?
Old Dec 25, 2006 | 11:59 AM
Boosted_SS's Avatar
under the dash on the drivers side i believe. look around the steering column.
Old Dec 25, 2006 | 12:04 PM
Blurred Vision's Avatar
If your talking about the amp for the 10" subwoofer on the ss/sc model then it's located in the subwoofer incloser I believe.
Old Dec 25, 2006 | 12:12 PM
Boosted_SS's Avatar
i believe there is an amp for the rest of the speakers as well. i think the whole thing for all the speakers is under the dash on the drivers side. PM hackabuse he may know
cobi's Avatar
the sub runs off the same amp as the the speakers.
Old Dec 25, 2006 | 12:17 PM
rick1217's Avatar
yes all the speakers run off the same amp, i removed my sub and there is no amp in the box, and only 4 wires going to the sub because it is a DVC sub, i also believe someone said the amp is a 6ch amp.
Old Dec 25, 2006 | 12:20 PM
Boosted_SS's Avatar
poineer 7 speaker amp is under the dash and the base model is in the head unit. i IM'd hackabuse to confirm this.
Old Dec 25, 2006 | 01:12 PM
ok..thanks all. if anyone wants to know the reason i asked is because im goin to hookup my Ipod to the amp. in my old car i had it hooked up through RCA cables from the amp using a Y cable to a headphone jack and it worked perfectly. now i am goin to attempt to do the same in this car. i will let you know how it goes.
Old Dec 25, 2006 | 01:18 PM
Boosted_SS's Avatar
this am does not have rca jacks
Old Dec 26, 2006 | 01:09 AM
EmperorJJ1's Avatar
all coblats other then the ss/sc only have the internal amp in the hu (or if the pioneer option was added) The amp is under the sterring column sorta where the clutch might be (pretty much directly above pedels)
the amp is a 6 channel amp with each channel wired to 2 ohm (sub is 2 ohm dvc using 2 channels, 6X9s are 2 ohm using 2 channels and the 6.5 and tweeter are either 2 ohm wired with a passive crossover somewhere for a final 2 ohm load or 4 ohm speakers paralleled to 2 ohm with some odd cross
Old Dec 26, 2006 | 06:54 PM
redline85's Avatar
So this might sound stupid.........What would be the best way to wire an after market amp? I just got a Kenwood KAC-6402(its a four channel amp) for Christmas and I am not sure if I should run the wires from the head unit or from the factory amp. By the way I have a ss/sc. So now my other question is how should I wire the sub to this amp?
Old Dec 26, 2006 | 07:01 PM
redline85's Avatar
Old Dec 26, 2006 | 07:52 PM
rick1217's Avatar
hmmmmm......you still have a stock deck?? pioneer 7 speaker?? i am not really sure if their is a way you can get it to work with the stock amp unless you have a line out converter. i never touch my stock deck or speakers but i removed my sub and used a line out converter to hook up a mono sub amp and my 2 15s..... i dont think an amp would be worth the pain of having to do all that, maybe trade it in for a sub amp and maybe a better sub....PM me if you need any help....
Old Dec 26, 2006 | 08:32 PM
EmperorJJ1's Avatar
if your using a 4 chan amp it will be tricky but you can use it for a sub... ive yet to look at the specs on the amp but im assuming it bridges to 2 chan 4ohm... you will need a 4 ohm dvc sub and the gains must be matched perfectly on each side for this to work.... good idea to go to a shop and get them to match gains with a multimeter (shouldnt cost much if thats all ur doing)
u will also need to use the line out convertor like mentioned to get signal from a stock deck
Old Dec 26, 2006 | 09:06 PM
Boosted_SS's Avatar
line out converter is definitely the only way to go! they don't cost much and sound comparable.
Old Jul 5, 2012 | 08:51 PM
MikesCobalt1's Avatar
Help
i bought an amp, 750.1watt kicker. and i am having super trouble installing it.. DO i need to buy more wires and crap?? or can i put it in the place the old one is now
Old Jul 6, 2012 | 03:11 AM
acoutu's Avatar
lol no you cant just swap them
you need to wire it on its own and bypass the stock amp so you dont double amp the speakers
Old Apr 16, 2014 | 10:05 PM
boostbalt's Avatar
Hey guys, here to resurrect this thread, because it's close to what I'm wondering..
I'm about to buy this Double DIN:
Pioneer 2-DIN CD/ MP3/ USB Car Receiver with iPod/ iPhone/ Android Control (FH-X700BT) : Double DIN Car Decks - Future Shop
I assume it'd be plug and play, or am I a moron?
Thank you!
Supercharged06SS
Dec 11, 2022 04:47 PM
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
Oct 13, 2015 09:32 PM
Stuff
Oct 1, 2015 05:47 PM
c_m_shooter
Sep 27, 2015 04:40 PM
