stock sub 08 ss/tc
Old Jan 5, 2009 | 08:22 AM
Roose00's Avatar
stock sub 08 ss/tc
curious if it is at possible to replace the stock sub with a powered one, instead of having a box in the trunk taking up all the room?
tried doing a search for this. hope this question hasn't been answered a 100 times.
Old Jan 5, 2009 | 08:29 AM
2007victoryred's Avatar
I dont see why not, I did it on an explorer I had a while back.
Old Jan 6, 2009 | 12:32 AM
EmperorJJ1's Avatar
ya you can replace it with an aftermarket shallow 10
Old Jan 6, 2009 | 12:45 AM
venum_us_2002's Avatar
i would recommend the rockford fosgate P3 shallow mount
http://www.rockfordfosgate.com/produ...n_US&p_status=
Old Jan 6, 2009 | 06:12 AM
Roose00's Avatar
ok great.
now can i use existing wiring for the stock sub and just add an amp? or should i cut out the existing wiring for the factory and run it like i would through the rear speakers? (not too familiar with the cobalt's audio system)
Old Jan 6, 2009 | 06:24 AM
JsavageSS/TC's Avatar
Wait a sec, can that hunk of plastic handle an aftermarket "amped" sub?????
Old Jan 6, 2009 | 12:26 PM
EmperorJJ1's Avatar
Originally Posted by Roose00
ok great.
what i normally recommend over cutting the wires is using T-taps. just disconnect the plug, tap those wires for signal and run new speaker wire thru the now empty screw hole in the back and seal it up
Old Jan 6, 2009 | 08:12 PM
Roose00's Avatar
so use the rear speaker wire and not the wire run for the sub?
Old Jan 6, 2009 | 11:39 PM
EmperorJJ1's Avatar
nah use the sub wires... theres a plug on it too
Supercharged06SS
Dec 11, 2022 04:47 PM
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
Jan 12, 2016 12:01 AM
Oct 13, 2015 09:32 PM
Stuff
Oct 1, 2015 05:47 PM
