stock sub
Old Mar 22, 2007 | 05:17 PM
leeserlee's Avatar
stock sub
is it possible to add another 10" pioneer sub from a cobalt ss to my existing system and headunit? its all stock but i can get another sub for cheap and i was wondering if that would work
Old Mar 22, 2007 | 05:21 PM
calchr2's Avatar
bump for an answer. im curious too
Old Mar 22, 2007 | 05:26 PM
gtzjustin's Avatar
if you would get another sub, you should probably get another amp. make sure you get the harness, cuz i dunno where you would get the plugs from and it would be a pain to hard wire it
Old Mar 22, 2007 | 05:34 PM
leeserlee's Avatar
what if i got an aftermarket headunit?
Old Mar 22, 2007 | 05:39 PM
gtzjustin's Avatar
the factory subs and amps will still work
Old Mar 23, 2007 | 07:28 PM
EmperorJJ1's Avatar
if you knew how to wire it up yes it will work. You will need another amp and another sub enclosure. Going aftermarket on the hu will work too but it may be slightly harder to wire.
Old Mar 23, 2007 | 11:14 PM
304rides's Avatar
if you buy aftermarket headunit then you will need a special wireing harness (most likely) to still use stock amp... i am not sure how they work in cobalts but in most cars the stock amp is not just plugged in with rca terminals... so a specail wireing harness is needed... check out cardomain.com and go to store.. and then select your car and model... it should tell you what you need... maybe
Old Mar 24, 2007 | 05:35 AM
EmperorJJ1's Avatar
ehh maybe... but it would be so much easier and efficient to get signal from the high levels offered thru the speaker outs
Old Mar 24, 2007 | 11:32 AM
xtremeGM's Avatar
Going with an aftermarket headunit wouldnt get the best performance from the stock sub and stock amp. (at least as far as bass goes) I still use the stock speakers and amp for the speakers just not the sub.
Supercharged06SS
Dec 11, 2022 04:47 PM
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
Oct 13, 2015 09:32 PM
Stuff
Oct 1, 2015 05:47 PM
