Sub box question.
Old Jan 23, 2014 | 02:12 AM
Smithkid21's Avatar
Sub box question.
So I'm looking at re-doing my sound system this year, and I want to with dual 12's. My only question is how would I get the box in the trunk?! I struggled to get my single 12 box in there. Is there a trick to get larger sub boxes in the trunk? It's a coupe btw. Thanks in advance!
Old Jan 23, 2014 | 02:23 AM
ae_xiong's Avatar
Ummm, bend your back seats down and shove it in that way?
Old Jan 23, 2014 | 03:20 PM
Smithkid21's Avatar
I was thinking of just removing the backs of the back seats and try and get it in that way? I'm just not sure. Cause it was a struggle to get a single 12 box in there. I can't imagine a dual 12 box.
Old Jan 23, 2014 | 04:30 PM
cbrenly09's Avatar
A box 32x16x16 will fit but you will have to remove the back seat and bottom of the seat I just put a 4.5 cf box with a single 15 in my 2door.
Old Jan 23, 2014 | 04:32 PM
Smithkid21's Avatar
That's kinda what I was thinking. If a box that big will fit, mine should have no problem. Thanks man!
Old Jan 23, 2014 | 04:33 PM
cbrenly09's Avatar
Not a problem what sub's are you gonna be running?
Old Jan 23, 2014 | 04:41 PM
UltraSilverSS's Avatar
That's the reason I downgraded to a single 8 in a 1 cu.ft box. I don't know if I would call an American Bass VFL8 a downgrade though
Old Jan 23, 2014 | 05:53 PM
Smithkid21's Avatar
I plan to run two Alpine SWR-12D2's with an MRX-M240 amp at 2 ohms.
Old Jan 24, 2014 | 01:36 AM
Mendomar06's Avatar
I would pair those to a Rockford Fosgate Power series amp. I would suggest a T1000-1bdCP, and run them at 1 ohm. Also those speakers like to have the correct airspace, if I were you i would build a custom box for them. Its not easy in our cars but it is doable and you will be a lot happier than with a custom box than those crappy pre-made boxes.
Old Jan 29, 2014 | 06:59 PM
Smithkid21's Avatar
May I ask why? Because if I get the MRX-M240 I would be running 2400 watts at 2ohms. Instead of 1000 watts at 1ohm with the T1000-1bdCP. Maybe I'm missing something here.
Old Jan 29, 2014 | 07:07 PM
You should be fine with 2400 RMS
Old Jan 29, 2014 | 07:09 PM
Old Jan 31, 2014 | 12:50 AM
2010T/C rpd's Avatar
I had two twelve in ken woods in my old one had them in a dual box also the box I had was wedged in the back and if it wasn't they wouldntve fit. I flipped the box on its face slid it in and flipped it back up and installed the speakers inside the trunk lol
Old Jan 31, 2014 | 12:16 PM
Mendomar06's Avatar
Because first of all those subs will not take all 2400watts they wont even handle all the power out of the T1000, and secondly your lights are going to dim like a son of a b***h. TRUST ME, I do this for a living, unless you plan on running secondary batteries and a bigger alternator, your gonna be unhappy. I did this exact setup in a 2014 Maxima and still had to add a secondary battery right before the amp to help with the dimming.
Old Jan 31, 2014 | 12:22 PM
Mendomar06's Avatar
Heres how that maxima turned out
Old Feb 1, 2014 | 07:23 PM
Smithkid21's Avatar
Well I plan on running a Kinetik hc2400 battery in the trunk to replace the original battery. And along with that, I am doing the big three upgrade.
Old Feb 1, 2014 | 08:26 PM
Did you do the work yourself or professionally? It looks clean.
Old Feb 3, 2014 | 12:24 PM
Mendomar06's Avatar
That is the best thing you can do. Have you looked into HO alternators, I know there are a few companies that make them for our cars.
I work at an audio shop, this is a customers car; and thank you.
Old Feb 3, 2014 | 04:55 PM
Smithkid21's Avatar
That is the best thing you can do. Have you looked into HO alternators, I know there are a few companies that make them for our cars. I work at an audio shop, this is a customers car; and thank you.
I haven't looked yet. Just starting to kick off this build/idea.
Old Feb 3, 2014 | 05:54 PM
cbrenly09's Avatar
Ohio generators is one of the best around for alts
Old Feb 3, 2014 | 08:51 PM
Smithkid21's Avatar
Just to give you guys an idea, this is what I plan on going with:
Pioneer AVIC-X940BT (already in the car)
Infinity Kappa 60.9 cs front speakers
Rear speakers stock (for now possibly unplug them)
Two Alpine SWR-12D2's in a vented enclosure
Alpine MRX-M240 amp @ 2 ohms
KnuKonceptz 1/0 OFC power/ground wire
KnuKonceptz 8 gauge OFC for speaker wire
Old Feb 4, 2014 | 07:46 PM
Mendomar06's Avatar
That is a good setup. Post up some pics of the finished result.
Old Apr 16, 2014 | 12:38 PM
Smithkid21's Avatar
Better late that never, right?
Ignore the volt gauge only reading 12.6 volts. I had it hooked up on the wrong battery. It's fixed now.
ineedacobaltss
Nov 7, 2015 02:25 PM
dennis69
Oct 20, 2015 04:49 PM
Jimmy Beilfuss
Oct 5, 2015 04:18 AM
Bohb
Sep 27, 2015 09:11 PM
c_m_shooter
Sep 27, 2015 04:40 PM
