Sub install on factory deck
Old May 8, 2007 | 12:37 AM
Grimfoo2's Avatar
So im sure this is posted somewhere, but im killing to hear some subs in my car, that little 10 inch is nice, but i want more. Any way to hook up an amp and some subs using the wiring from the stock pioneer sub and stock deck in the car? I want to keep the stock cd player in the car otherwise its off to the performance parts for me. If any body's got some ideas or pictures of this please let me know!
Old May 8, 2007 | 12:50 AM
jefferyss's Avatar
i went down to the local best buy and picked up a line invertor from schoch for preouts.basically a plastic module with 2 adjustment dials on it with 4 wires comming out and 2 pre out lines. you cut into your factory rear speaker plugs and splice in 2 wires per side, tape it all back up and your rear speakers power you amp preouts.hook up your amp and wiring and tune in you invertor for more power. this system works great.i kept my factory 10 in the trunk and also run 2 rockford 10's in a rockford made ported box with amp. . . i have to keep ny child seat tethers in the up posistion or they bounce hard lol, and to top it off . . . my sunroof pulse's. it gets pretty intense lol , good luck :P
if i new how to post pics on here i would show you the components and my set up but i have no idea how to figure out the coding lol
Old May 8, 2007 | 11:22 PM
Grimfoo2's Avatar
Thats awesome, how does that work as far as the remote and what about the bass control on the deck? does that still work?
Old May 8, 2007 | 11:58 PM
jefferyss's Avatar
everything works great . . . you just got to put the time in and dial it all in and stil have full controls of stereo functions
Old May 9, 2007 | 02:13 PM
Pontiac.G5's Avatar
this is how i wired my subs up
you can put an inverter instead of the crossover... i jus hae it that way cause i didn't have one at the time
Old May 9, 2007 | 03:08 PM
jefferyss's Avatar
Awsome Diagram Pontiac.g5 , Very Good Discription
Old May 9, 2007 | 09:48 PM
Grimfoo2's Avatar
Yeah, i like that diagram. it helps a lot. just one more question, where did u hook the remote up to? because its a stock deck would that go to the fuse box as well?
Old May 10, 2007 | 10:13 AM
jefferyss's Avatar
WELL,OF ALL PLACES TO HOOK IT UP TO . . . .I SPLICED IT INTO MY HEATER/AC FAN MOTOR WHICH IS JUST UNDER PASS FRONT DASH . IT WAS EASY AND VERY ACCESIBLE SO I RAN THE WIRE TO THERE,WORKS GREAT
Old May 10, 2007 | 01:38 PM
Pontiac.G5's Avatar
i have the remote wire hooked to the sunroof fuse in the fuse box under the dash on the passenger side... but i also have a switch it the line so that i can turn it on and off manually too... so my gf don get mad at me for it bein too loud
06MetallicBalt
Jul 20, 2025 08:47 PM
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
dennis69
Oct 20, 2015 07:39 AM
justinchinn
Oct 2, 2015 12:18 PM
