sub problem
Old Aug 17, 2007 | 03:55 PM
JRANGER's Avatar
the factory rca or factory speaker wire?
Old Aug 17, 2007 | 03:56 PM
M&CBlackSS's Avatar
i think the speakers wires
Old Aug 17, 2007 | 03:57 PM
JRANGER's Avatar
so you wired up rca's to the speaker wire that hooked to the subs?
Old Aug 17, 2007 | 04:00 PM
M&CBlackSS's Avatar
yea thats wrong isnt it ?
lol i knew i shouldnt listen to my friend
Old Aug 17, 2007 | 04:01 PM
JRANGER's Avatar
well it is and it isnt. You need a converter box to convert it over. They sell them at like Circuit City
Old Aug 17, 2007 | 04:02 PM
M&CBlackSS's Avatar
what does that do?
Old Aug 17, 2007 | 04:05 PM
JRANGER's Avatar
it converts the signal into a preamp output and gets rid of noise. Its called a Line Out Converter.
You should be able to find them at most electronics places. RadioShack, BestBuy, Electronics Express, Circuit City, and Autozone and such
Give that a try and let us know
Old Aug 17, 2007 | 04:07 PM
M&CBlackSS's Avatar
ok but will that fix the problem?
Old Aug 17, 2007 | 04:09 PM
JRANGER's Avatar
It should. You may want to change your remote wire as well other wise when you roll up the window it will screw with the amp
Old Aug 17, 2007 | 04:10 PM
M&CBlackSS's Avatar
cool that 4 the info
Old Aug 17, 2007 | 04:19 PM
  #36
WunSick's Avatar
Has the amp ever been used on any other deck ? any other sub? Im pretty sure your ohms are not matching up propperly. My guess is the stock sub is a 8ohm sub, and your amp is prolly dual channel 4ohm. How do you have the amp bridged ? Is it a mono channel amp ? This is [probably] a very easily workable issue.
just threw some things for you to try out.
EDIT: ya after actaully 'reading' some replies, could _also_ be the rca hookup, i can only assume your taking signal before it gets to the stock amp ? hopefully not from the wires directly from amp signal outs. Could be overloading the new amp with the signal in, or not matching the ohm load. From my previous experience that is.
Old Aug 17, 2007 | 04:29 PM
  #37
M&CBlackSS's Avatar
im not shur i bought the amp used form a resale shop in town and my buddy
hook it up it sounds good its just that when i turn the radio up the sub stops hitting
Old Aug 17, 2007 | 04:35 PM
  #38
Area47's Avatar
Rent me! per hour
power does not kill speakers. distortion does.
control is the key.
turbochargedss2012
Sep 20, 2023 12:17 PM
yellow dragon
Sep 28, 2015 09:49 PM
Iceberg
Sep 28, 2015 01:31 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
