sub under seat
Old May 28, 2012 | 11:31 PM
deereboy4320's Avatar
sub under seat
I was wanting to put a sub under the passenger seat instead of in the trunk. does someone make one that small?
Old May 28, 2012 | 11:34 PM
tony2toness/sc's Avatar
yea umm i think pioneer there called shallow mounts look them up dont know if there good or not
Old May 29, 2012 | 06:36 AM
EmperorJJ1's Avatar
theres not enough room. its physiclly possible to fit one there but theres no room for a box or for it to have movement. and cant really raise our seats either
Old May 31, 2012 | 12:48 PM
alright. it was worth asking. I hate how we have it in the trunk
Old May 31, 2012 | 04:48 PM
EmperorJJ1's Avatar
any specific reason?
Old May 31, 2012 | 06:17 PM
Crav3's Avatar
It should be possible my brother got 4 rockford punch subs 8 inch behind the seats of his 2006 4door silverado.
Old May 31, 2012 | 07:49 PM
warrenb213's Avatar
blocks?
OP, you should just put it in the trunk. too much of a hassle to do it under the cobalts seats as there is no room, not nearly as much as the silverado just referred to. trucks get it done because of constraints on space usually though i've seen some crazy setups.
if you are concerned about space in your trunk get a smaller sized sub with a smaller magnet and that's a bit more shallow. then you could do a smaller box in your trunk. though i wanna tell ya, the bigger boxes usually help to make the bass pronounced and being that a car like ours kinda sucks as a sound stage choosing a speaker/amp combo is a little more thought-worthy as to enhance and maximize the audio capabilities of the car.
this all said, i had to sacrifice a nice larger ported sub box for a much smaller sealed box when i decided to install the carpc. while the sealed box does give a sharper bass, the follow-thru is not like it was with the larger port box. still sounds amazing but damn this sound stage.
Old Jun 1, 2012 | 01:53 AM
Crav3's Avatar
My brothers single cab s10 also has 4 10" kicker cvx subs behind his seats lol sound crazy loud! And I would so the oem sub box bit thats just me
Old Jun 1, 2012 | 05:01 PM
EmperorJJ1's Avatar
right ive done 4 rf 8s in a 2006 body style 4 door truck before. also re audio dd audio and kicker off the top of my head.
its simple math take out a measuring tape and measue from the floor (which is higher due to the support beam and the AC duct over that) and measure to the lowest point of the seat. then find a sub and add at the very minimum a 1/2 an inch to that and you have what is possible but will sound like ****.
I mean unless your cutting out the floorboard to make this happen your better off buying lottery tickets or something bc its a huge waste of money
Old Jun 1, 2012 | 05:05 PM
Crav3's Avatar
^^ you ate right won't sound that good. Be better off getting a small box or the oem sub box
chefhhr
Oct 26, 2015 10:36 PM
dennis69
Oct 20, 2015 04:49 PM
Tupp
Sep 29, 2015 11:07 PM
Cptnslo
Sep 24, 2015 09:32 AM
