Taking the dead panel out?
Old Aug 11, 2005 | 03:09 PM
Mercury's Avatar
The little panel below the headunit, is there anything behind that? I was asking because I was going to intall something there. Also how do you take it out?
thanks!
Old Aug 11, 2005 | 03:57 PM
disp507's Avatar
Smile
Are you talking about the little panel with a square black painted area just above the climate controls and below the stock head unit? If so that is where the heated seat controls go, or so I'm told.
If you pull the whole face plate off from around the stereo and climate controls it should just be a few screws.'
HTH,
Disp507
Old Aug 11, 2005 | 04:12 PM
TnSS's Avatar
I haven't taken it off to look, but it looks like it is attached to the frame around the HU and the A/C controls (you may have to punch it out and sand down the sides. I don't like it either, so if you have any ideas on what to put in there, please share
Old Aug 11, 2005 | 11:43 PM
MichiganMike's Avatar
I just had my head unit and an alarm installed and I ended up having the shop mount my LED for the alarm there. It is a useless piece of plastic. It looks like a spacer.
Old Aug 12, 2005 | 05:40 PM
Mercury's Avatar
How do you remove the plate surrounding the headunit and HVAC controls?
Old Aug 12, 2005 | 11:36 PM
If I remember correctly it's all held in by clips. I peeked when the installer was putting in my radio and that's all I saw, but I think you have to remove both trim pieces to the left and to the right of the plate.
Old Aug 13, 2005 | 12:47 AM
TnSS's Avatar
i haven't done it, but i've seen it taken off on a tv show, and it looks like all the silver trim pieces just pull off (clips)
Old Aug 15, 2005 | 06:23 PM
Mercury's Avatar
Old Aug 15, 2005 | 06:39 PM
philco_3's Avatar
Proud Playstation 3 Owner
Is there anyone out there that has a camera and the time, that can do a "How To"... for taking the dash apart?
Old Aug 15, 2005 | 11:09 PM
If you are looking at taking it out to get to your head unit or that dead plate, I saw what it looked like when I had my head unit installed. The 2 trim pieces on either side pull right out by way of clips and so does the radio/hvac trim piece. I did not see any screws that had to come out. Just take it easy and you should be able to do it. If i'm wrong, I'll hide.
Old Aug 16, 2005 | 08:28 AM
danklite's Avatar
I have taken my dash apart it seems like a million times. The two trim pieces do infact pull off, and also the trim around the radio and hvac controls. The only screws that you will get into are underneath all of the trim and in and along the center console. Just be careful with the trim pieces so as not to break them when pulling them off!!
Old Sep 28, 2005 | 01:43 PM
swatthefly's Avatar
yep... heated seats go there, also passanger airbag and seatbelt indicator.
06MetallicBalt
Jul 20, 2025 08:47 PM
bigdeertz
Nov 17, 2016 09:41 AM
hacadacalopolis
Oct 28, 2015 06:09 PM
Oct 20, 2015 09:56 PM
