Taking the dead panel out?
The little panel below the headunit, is there anything behind that? I was asking because I was going to intall something there. Also how do you take it out?
thanks!
thanks!
Are you talking about the little panel with a square black painted area just above the climate controls and below the stock head unit? If so that is where the heated seat controls go, or so I'm told.
If you pull the whole face plate off from around the stereo and climate controls it should just be a few screws.'
HTH,
Disp507
HTH,
Disp507
I haven't taken it off to look, but it looks like it is attached to the frame around the HU and the A/C controls (you may have to punch it out and sand down the sides. I don't like it either, so if you have any ideas on what to put in there, please share
If I remember correctly it's all held in by clips. I peeked when the installer was putting in my radio and that's all I saw, but I think you have to remove both trim pieces to the left and to the right of the plate.
Originally Posted by Mercury
How do you remove the plate surrounding the headunit and HVAC controls?
If you are looking at taking it out to get to your head unit or that dead plate, I saw what it looked like when I had my head unit installed. The 2 trim pieces on either side pull right out by way of clips and so does the radio/hvac trim piece. I did not see any screws that had to come out. Just take it easy and you should be able to do it. If i'm wrong, I'll hide.
