Turning the Side Markers into Turn Signals.
Old Oct 30, 2008 | 02:22 PM
Blue_Balt's Avatar
A lot of cars come with turn signals that are found on the side of the cars. Would it be feasible to try to do it on the Cobalt's side markers?
Old Oct 30, 2008 | 02:29 PM
brickerenator's Avatar
i would think so
couldn't be that hard
Old Oct 30, 2008 | 02:33 PM
elecblue06's Avatar
not really hard.. someone did it with an ion you could also think about signals in the side mirrors
Old Oct 30, 2008 | 02:34 PM
YelloEye's Avatar
Sounds like a simple job, only problem would be wiring up a relay so if the signals arent flashing that they stay constant as a marker
mkulrey13's Avatar
Just cut the power wire going to it and run the power wire from the tail lamp to it.
Old Oct 30, 2008 | 02:35 PM
elecblue06's Avatar
run it off the DRL isn't that the same as the turn signal ?
it is on the ions
Old Oct 30, 2008 | 02:39 PM
Blue_Balt's Avatar
That sounds like the best way of going about it.
Thanks.
I also want to do that eventually as well.
Old Oct 30, 2008 | 02:40 PM
BLAZIN07SS's Avatar
I'm too JDM for you
Thanks.
i wouldnt do that. you are going to draw too much power through those wires. possible electric fire. do it right with a relay and proper fuses
Old Oct 30, 2008 | 02:41 PM
Blue_Balt's Avatar
it is on the ions
The DRL on my car is the actual headlight, not the parking light.
I'll definitely keep that in mind.
Old Oct 30, 2008 | 06:52 PM
EmperorJJ1's Avatar
so are you talking about the amber ones up front or the red ones in the back?
06MetallicBalt
Jul 20, 2025 08:47 PM
Solaris99
28
Mar 15, 2017 01:22 PM
biniecki
Oct 25, 2015 02:23 PM
roth
Sep 26, 2015 12:16 PM
