Upgraded systems what are you running?
Old 10-29-2012, 09:06 AM
  #201
LamboW9's Avatar
Almost anything id say. From akon to eminem. Maroon5. I also like rock music like shinedown. Creed. 3 doors down. Foo fighters and a little godsmack. Tool. I like quite the variety of music. I dont know what they were playing in the pumpkin smd video but those seemed pretty badass too.
Old 10-29-2012, 10:26 PM
  #202
tru2nrtt777's Avatar
Originally Posted by LamboW9
i gotta be honest i'm definitely feelin those rockford fosgate speakers. they are sexy as ***. someone point me in their direction! i gotta go start searchin but i have a feelin they are expensive.
Hopefully you got them from sonicelectronix otherwise you may have payed too much. From my experience they have the cheapest RF **** with a warranty.
ok so i been searching. obviously for the whole damn evening here. good thing work gives me plenty of free time.
this is what i think i'm gunna go with in terms of amps.
For mids/highs - Rockford Fosgate Prime 250-4 (its 40x4 @ 4 ohm) or (65x4 @ 2 ohm)
For sub(s) - Rockford Fosgate Prime 500-1D (its 250x1 @ 4 ohm) or (500x1 @ 2 ohm), this gives me the flexibility to either run 2 light subs or one strong one.
I'm kinda thinkin about just getting one Punch stage 3 2 ohm. that thing would be perfect with that amp.
What yall think? Its very reasonable price range as well.
Good entry setup, just remember if you ever want to get very crafty and add to your current components... not replace... you can run each channel in parallel (assuming what you get is also 4 ohm) and run it all at two ohm loads. Also the P3 will be fine in either box but you seem to want a decent SQL setup so I would run sealed. Also I have never used RF's calculator, for a simple square/wedge you can use the12volt.com's calculators. For some crazy **** you could check this website's calculator's out.
Old 10-30-2012, 02:12 AM
  #203
EmperorJJ1's Avatar
ill see if i can get you a design for a good 40hz box.
Old 10-30-2012, 09:47 AM
  #204
LamboW9's Avatar
thanks guys i appreciate all the help. and yes i did definitely by from sonic electronics. their deals were pretty damn good. like 100$+ off of most MSRP. I think i'll be happy with it. if I do want to go with more bass down the road i'll prolly snag another 500-1d and a p3 but i believe i'll be content with these. and yes i ordered the p3d4-10
Old 11-01-2012, 06:55 PM
  #205
LamboW9's Avatar
heres a good question for you guys. would it be better to fabricate a box built into the lay of the intended area such as fiberglassing everything or would it be easier/better to build a box out of MDF and then build the front face and surrounding "cover plate" out of fiberglass?
Old 11-01-2012, 08:32 PM
  #206
Vtec Rep
BPacak's Avatar
wish i could help you but i know nothing about boxes haha.
kinda thinking about not running my stock speakers in the saturn because they suck and just gettin like 4 mid range 6.5 o2's or something to go with the 12in fi ssd but idk how that would sound haha.
Old 11-01-2012, 08:36 PM
  #207
LamboW9's Avatar
anything is better than stock. even the stock pioneers were garbage. in fairness i don't think good speakers are that expensive. i mean if your not going into competitions or anything you could get a good set for a very reasonable price range.
Old 11-01-2012, 10:11 PM
  #208
Honestly it would be easier to build one from 3/4 MDF although I am not sure what you are refering to making a "cover plate" from glass. Especially if you want to build box specs to the woofer. If you want a design more tucked like the stock sub then glass where you want it. Just remember when glassing put some plastic wrap or foil(what I perfer)down so the box doesn't stick to your carpet... Don't skimp out on the foil either, I usually do two layers just to make sure.
Plus one. lol.
Old 11-01-2012, 10:16 PM
  #209
LamboW9's Avatar
i show a lot so i'd like a more cleaner but still custom look, yanno not just a box. so if i built say the entire box but didn't build the front of it and instead fab'd out the sides and where I wanted to cover an then made the entire front glass that way it still gives the look of a fully glass box but it will have the box built behind it so it has the exact specs that the subwoofer requires to operate at peak perameters.
i'd be open to doing the entire thing in glass but i don't think it would come out to spec and putting a box inside glass would only inhibit the bass so building just a glass front would be optimal right?
Old 11-01-2012, 10:17 PM
  #210
EmperorJJ1's Avatar
in most cases as far as bass is concerned a square box is louder then any random weird shape. but random weird shapes have advantages such as space savings
Old 11-01-2012, 10:21 PM
  #211
LamboW9's Avatar
but i could box the back and glass the front and it would still look custom yet have the box sound , that may end up being a good choice I think, it would also be much easier to do versus a full box out of glass for my first glassing project.
o yea, hurricane sandy is delaying the arrival of my products. damnit.
Old 11-01-2012, 10:26 PM
  #212
EmperorJJ1's Avatar
uve seen my box right? its squarish with a fiberglass cover
Old 11-01-2012, 10:27 PM
  #213
Vtec Rep
BPacak's Avatar
my sub is on the way finally, even though its only been like 2 weeks haha.
Old 11-01-2012, 10:40 PM
  #214
LamboW9's Avatar
don't hate on me but i don't think i have. i've seen your CF door panel build which came out pretty sick. post up if you don't mind or direct me. i'll rotate through your gallery in a minute to see if its in there as well.
Old 11-01-2012, 10:41 PM
  #215
LamboW9's Avatar
nicee!! FI and some of those other more custom brands are crazy expensive. you got serious when you made your decision huh. did you finish routing your wires or makin your box yet?
Old 11-01-2012, 10:42 PM
  #216
Vtec Rep
BPacak's Avatar
i havent done anything haha, it rained for like 5 days straight so i was being lazy.
Old 11-01-2012, 10:54 PM
  #217
LamboW9's Avatar
haha, yea i kno that feeling. i CF vinyld my gas cap and door trim before the storm hit. been miserable ever since. you kno which route your going yet with your box, glass or just MDF or mix like emps?
and i think emp was talkin about this bein his:
Old 11-02-2012, 01:06 AM
  #218
EmperorJJ1's Avatar
bingo... who spys a cobalt grill in the background
Old 11-02-2012, 04:31 PM
  #219
LamboW9's Avatar
haha, i didn't even notice the grill back there. that's a pretty nice cover tho, i have a feeling mine won't come out that nice but i'm going to try.
Old 11-04-2012, 01:17 PM
  #220
cobaltsskid1200's Avatar
In the car i have a 12'' pioneer shallow sub. pioneer amp.
Specifics below...
Pioneer TS SWX310 powered by Pioneer GM D7500
yes i know shallow boxes suck but i like my trunk space!
and it hits hard enough for my taste
waiting to go in car
Rockford Fosgate Punch P1692 6x9''
door speakers
Rockford Fosgate P1675 Punch 6.75''
i want to order the Rockford Fosgate Prime R300-4 300-Watt Multi-Channel Amplifier
to power just the door speakers and shelf speakers. it sends 50rms and they are rated for 75 and 60. hoping it will turn out well
headunit i where im lost, want a pioneer 1400dvd but not sure.
SUGGESTIONS AND EXPERIANCES PLEASE!
Old 11-05-2012, 04:14 PM
  #221
Vtec Rep
BPacak's Avatar
the rcas i got have the remote wire in the middle, never saw that before haha.
sub should be here wednesday then i just have to get the box made and its ready to go in the car, hopefully i get lucky and we get a random warm day and i have off work.
Old 11-05-2012, 04:30 PM
  #222
LamboW9's Avatar
lol. thats a lot of luck requesting goin on. thats pretty cool what you said about a remote wire being in the middle of your rca's that beats the hell outta running a separate wire just for remote. if i were you i'd start wiring now, lol. not that its hard tho.
hopefully i get my stuff tomorrow. the hurricane delayed my **** so i'm a little perturbed but o well.
Old 11-05-2012, 04:36 PM
  #223
Vtec Rep
BPacak's Avatar
yeah i was like wtf is this, then i noticed they didnt give me a remote wire so im like ohhh that makes sense haha. il probably just wait, supposed to be like $60 on saturday. gonna check some places tomorrow about the box.
Old 11-05-2012, 05:11 PM
  #224
LamboW9's Avatar
its gonna be 60 dollars on saturday? nice! lol. to make a box is actually easy if your just going standard box. probably a lot cheaper as well. just get the specs from factory on what volume it should be and what box type it works best for your needs and the box wizards (calculators) allow you to add in measurements to fit your tastes and it will spit out the volume that will be in the box that way you can get as close to the volume required while still fitting box length x width x height to what will suit you best. 3/4 MDF is reasonably cheap.
Old 11-05-2012, 05:31 PM
  #225
Vtec Rep
BPacak's Avatar
Yeah Idk why I put the $ in there haha. And I'm probably just gonna have the box built, a lot easier haha.
Quick Reply: Upgraded systems what are you running?
